Selenium HL4750-SLF 2" Bi-Radial Horn 40x20 4-Bolt
Brand:|Model: HL4750-SLF|Part # 264-329
Selenium manufactures larger horns that are ideal for stage monitors, side-fill, and most P.A. applications.
List Price$164.80
You Save15%
$139.99
Part # 264-329
Selenium manufactures a variety of professional horns to complement their range of drivers. Each horn is crafted of high quality molded fiberglass, diecast aluminum, or ABS and provides different angles of dispersion to allow for maximum and optimal sound coverage to suit the particular application. Selenium horns can be used in the most demanding of touring environments. Larger format horn is ideal for side-fill and most P.A. applications. Reinforced fiberglass construction.
Specifications: • Horn type: Bi-radial • Minimum frequency: 400 Hz • Nominal dispersion: 40° H x 20° V • Throat diameter: 2.0" • Mounting type: 4 hole • Dimensions: 17.52" x 11.02" x 13.86" • Selenium #HL4750-SLF.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionFiberglass
  • BrandSelenium
  • ModelHL4750-SLF
  • Part Number264-329
  • UPC7896359508006
  • Product CategoryHorns & Waveguides
    (1 Reviews)
  • Weight7.94 lbs.
View similar products to the Selenium HL4750-SLF 2" Bi-Radial Horn 40x20 4-Bolt
in the Horns & Waveguides product category.
Selenium HL4750-SLF 2" Bi-Radial Horn 40x20 4-Bolt is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from great horn for the priceI've used a bunch of different horns with my Selenium D405 midranges and this horn is very satisfying. It does not sound like a horn and loads down to 400 HZ. Perfect for my application on top of my Klipschorns. This combo is much better than stock Klipschorn horn/driver
Date published: 2009-04-11
  • 2016-02-12T06:22CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_264-329, PRD, sort_mostRecent
Can this horn be used with a 2" cone driver like the Jordan JXR6HD
I would somehow use this driver, attach it to the horn. Then, build a box to produce the volume necessary for the acoustic suspension of the driver. This design would be very similar to the midrange box Edgar Horns that cut out at 500HZ. How would the sensitivity increase if I use the driver in such implementation?
Asked by: Bemopti123
No, the Jordan ICE6HD is a great wide range 100 Hz - 40khz. Mid-tweeter speaker but it is an aluminum cone type speaker and not a horn driver. This type of horn lens allows for designing various dispersion characteristics with various horn drivers that screw to the throat of the lens. The Jordan mounts like a traditional speaker to your cabinet.
Answered by: Nitnub
Date published: 2012-04-05
  • 2016-02-12T07:07CST
  • loc_en_US, sid_264-329, PRD, sort_recentQuestionsFirst
