Selenium HL14-50 2" Exponential Horn 45x45 4-Bolt
Brand:|Model: HL14-50|Part # 264-316
Conical, narrow dispersion exponential horn for long throw monitor and P.A enclosures.
List Price$34.90
You Save28%
$24.99
Part # 264-316
Selenium manufactures a variety of professional horns to complement their range of drivers. Each horn is crafted of high quality molded fiberglass, diecast aluminum, or ABS and provides different angles of dispersion to allow for maximum and optimal sound coverage to suit the particular application. Selenium horns can be used in the most demanding of touring environments. Conical, narrow dispersion exponential horn for long throw monitor and P.A enclosures. Aluminum construction.
Specifications: • Horn Type: Exponential • Minimum Frequency: 700 Hz • Nominal Dispersion: 45° H x 45° V • Throat Diameter: 2.0" • Mounting Type: 4 hole • Dimensions: 6.1" W x 6.1" H x 5.1" D • Selenium #HL14-50.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionAluminum
  • BrandSelenium
  • ModelHL14-50
  • Part Number264-316
  • UPC7896359519347
  • Product CategoryHorns & Waveguides
    (3 Reviews)
  • Weight1.9500 lbs.
View similar products to the Selenium HL14-50 2" Exponential Horn 45x45 4-Bolt
in the Horns & Waveguides product category.
Selenium HL14-50 2" Exponential Horn 45x45 4-Bolt is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from wowI was blown away by the quality and how quickly PE got it to me. This thing could be a part on a tank is is so well built!
Date published: 2008-06-11
Rated 5 out of 5 by from Very, Very well Built, All metal constuction.....Would have been nice. If it had the four 1/4"x 1" bolts with it.
Date published: 2008-03-20
Rated 5 out of 5 by from Excelent for hight power stage monitorExcelent!
Date published: 2007-08-23
  • 2016-02-06T07:02CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_264-316, PRD, sort_mostRecent
I currently Selenium D4400ti and Selenium HL4750SLF. I get some massive distance but the dispersion is to shallow. Is this horn considered a short throw horn? I need better dispersion but good distance. (and inexpensive)
Asked by: Keilamym
This will provide slightly wider dispersion and certainly taller dispersion. This is 45x45 as opposed to 40x20 from the HL4750SLF so the width would be improved. This will also have great distance coverage as well. This would be a good choice.
Date published: 2015-03-19
1) The front flange on this horn looks different than what is depicted in the Specification Sheet. Which one will the customer receive? 2) If the customer receives the horn depicted by PE.com, what is the distance between the flats of the front flange?
Asked by: FireCloud
I pulled the horn from stock and verified that the picture on our site is not correct, the horn matches the Selenium spec sheet. The distance across the flats is 6-1/4", although they are not exactly flat, they are slightly rounded.
Date published: 2014-07-10
  • 2016-02-06T08:25CST
  • loc_en_US, sid_264-316, PRD, sort_recentQuestionsFirst
