Selenium D3501Ti-Nd 2" Titanium Neo Horn Driver 4-Bolt 8 Ohm
Brand:|Model: D3501Ti-Nd|Part # 264-457
Selenium's D3501Ti-Nd 2" horn driver provides truly professional high output/low distortion performance when used in concert touring loudspeakers, stage monitors, and other high output speaker systems.
Part # 264-457
  • Efficient, lightweight neodymium magnet
  • Exclusive DPD (Driver Protection Device) technology for reliable operation
  • Flat CCAW voice coil on advanced polyimide former
  • Optimized aluminum injected phase plug avoids phase cancellation problems
  • Precisely engineered diaphragm and alignment mechanism for easy field replacement
  • For use with 2" 4-hole mount horns
The Selenium D3501Ti-Nd 2" exit compression driver is intended for professional applications that demand high SPL and low distortion. A structured "snowflake" embossed pure titanium diaphragm and IPF (Impregnated Polymer Fiber) surround contribute to the driver's high sensitivity, low distortion, and smooth, extended frequency response. The D3501Ti-Nd's optimized aluminum injected phase plug avoids cancellation issues, and the rear cover, also aluminum, ensures the driver's housing is compact yet robust.
A powerful neodymium magnetic assembly with copper shorting ring reduces distortion and minimizes HF-robbing voice coil self-inductance. The CCAW (copper clad aluminum wire) voice coil is wound on a high temperature polyimide former. Selenium's DPD (Driver Protection Device) circuit utilizes a PTC and a HPCCR resistor, assuring greater reliability when the driver is subjected to overload conditions and abuse. A precisely engineered dome/coil structure and alignment mechanism guarantees fast, easy field repair in the rare event of a diaphragm failure.
The D3501Ti-Nd is recommended for use in concert touring loudspeakers, stage monitors, and other high output speaker systems. Its small size makes it useful for the design and construction of ultra-compact enclosures or line arrays. The D3501Ti-Nd's 4-bolt pattern facilitates mounting on industry-standard 2" throat horns.
Specifications: • Power handling: 150 watts (w/xover, 800 Hz, 12 dB/octave) • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-25,000 Hz (no crossover) • SPL: 111 dB 2.83V/1m • Magnet weight: 21.5 oz. neodymium • Dimensions: Overall diameter: 4.96", Depth: 4.06" • Weight: 6.83 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)150 Watts
  • BrandSelenium
  • ModelD3501Ti-Nd
  • Part Number264-457
  • UPC7896359512812
  • Product CategoryHorn Drivers
  • Weight7.25 lbs.
View similar products to the Selenium D3501Ti-Nd 2" Titanium Neo Horn Driver 4-Bolt 8 Ohm
in the Horn Drivers product category.
