Selenium D250-X GW 1" Phenolic Horn Driver 1-3/8"-18 TPI
Brand:|Model: D250-X GW|Part # 264-204
The Selenium D250-X horn driver offers outstanding performance for midrange reproduction in professional PA systems. Its 1-3/8"-18 TPI threaded exit is compatible with many popular screw-on horns.
List Price$47.99
You Save21%
$37.99
Part # 264-204
  • Low distortion and extreme clarity in the critical mid or vocal range
  • Phenolic diaphragm for smooth response and high reliability
  • Standard 1-3/8"-18 TPI screw mount
  • Popular driver for Leslie rotating speakers and guitar "talk boxes" too!
  • Sold individually
The Selenium D250-X is an affordable compression driver with a lightweight, strong phenolic diaphragm designed for midrange reproduction in indoor/outdoor background sound systems and small PA systems alike. The D250-X's 1" threaded exit fits all Selenium horns with model numbers ending in 25. High temperature wire used for the voice coil is wound on a Kapton former to withstand high operating temperatures. The nearly indestructible phenolic diaphragm structure allows for easy, cost-effective replacement, in the unlikely event of failure.
Specifications: • Power handling: 150 watts (w/xover, 500 Hz, 12 dB/octave)/200 watts (w/xover, 1,000 Hz, 12 dB/octave) • VCdia: 2" • Impedance: 8 ohms • Frequency response: 400-9,000 Hz (no crossover) • SPL: 107 dB 1W/1M • Magnet weight: 11.7 oz. • Dimensions: 4.41" dia. x 3" D • RPD250-X replacement diaphragm available, see Related Items tab.
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)150 Watts
  • BrandSelenium
  • ModelD250-X GW
  • Part Number264-204
  • UPC7896359515684
  • Product CategoryHorn Drivers
    (71 Reviews)
  • Weight2.7 lbs.
View similar products to the Selenium D250-X GW 1" Phenolic Horn Driver 1-3/8"-18 TPI
in the Horn Drivers product category.
Selenium D250-X GW 1" Phenolic Horn Driver 1-3/8"-18 TPI is rated 4.7465 out of 5 by 71.
Rated 5 out of 5 by from Awsome Product!Works perfectly! Couldn't ask for better. Great for talk boxing.
Date published: 2015-09-23
Rated 5 out of 5 by from Great equipment!This unit is twice as powerful as the original. Great stuff!I'm ordering another unit.
Date published: 2015-06-02
Rated 5 out of 5 by from Fantastic Driver!Just got a pair of these drivers today, did a quick hookup to test them out and all i can say is wow. I'm adding these to HT setup. I turned on all speakers fronts, center, and all subs and these stood out the most.... They get LOUD. they are a tad harsh right now but that can be adjusted later.
Date published: 2015-05-22
Rated 5 out of 5 by from amazing thats all i can sayI am glad I purchased this it is an amazing midrange for the price and you can not beat JBL they are definitely one of the best that you can find even their selenium series raw speakers
Date published: 2015-03-11
Rated 5 out of 5 by from THE go-to mid horn driver!For high power, clear and loud mid-range, this is the driver. For screaming B3 sounds, this can't be beat. I use these exclusively in our high-end products and it never fails to drop jaws when people hear it.
Date published: 2014-08-30
Rated 5 out of 5 by from Great sound for hornsUsing for replacements on university sound horns and get good results, sound, and volume to be heard at motor sports events.
Date published: 2014-07-11
  • 2016-02-07T06:47CST
  • co_hasreviews, tv_0, tr_71
  • loc_en_US, sid_264-204, PRD, sort_mostRecent
can you recommend a 12 inch 8 ohm woofer to work well with this driver using also a eminence PXB2 800 ohm cross over
Asked by: Wharp
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-08-03
would this driver work well with your Eminence PXB2 : 800 crossover
Asked by: Wharp
Yes this will work well with that crossover.
Date published: 2015-08-02
Do u know if this has been used as a replacement horn driver for a motion pro sound pro 3t?  If so, was it a very involved job that shd only be done by a professional, or pretty straight fwd? Most imp.. was there an improvement regarding sound quality?
Asked by: scoccoelloco
We do not have a direct cross reference for this type of thing. If the original horn driver used a standard threaded mount, this should work without issue and be relatively easy to replace.
Date published: 2015-07-13
What crossover do you recommend for this? I'm using an eminence 15 lfa woofer.
Asked by: Whitefeather1111
To avoid beaming issues, I would not cross a 15" woofer much higher than about 800 Hz. Since this driver can handle a crossover as low as 500 Hz, anything between these numbers would work well. If you are looking for a two way design, something like below would work well.http://www.parts-express.com/eminence-pxb2-500-2-way-speaker-crossover-board-500-hz--290-630
Date published: 2015-07-28
What happens to power handling if a 24db crossover is used at say 500hz
Asked by: nathan61
The power handling will increase a little, but I cannot give you a specific number. Even 100 watts RMS into this driver will be plenty for most applications.
Date published: 2015-05-12
Would it be possible, or advisable to parallel a piezo tweeter off of these to extend the frequency range for use as a midrange cabinet driven by a dedicated amp and used with an active crossover?
Asked by: TLM7
There's nothing wrong with doing this. You will have to play around with the number of piezos that would match the output of the mid the best.
Date published: 2015-03-18
  • 2016-02-07T07:26CST
  • co_hasquestionsanswers, tq_18
  • loc_en_US, sid_264-204, PRD, sort_recentQuestionsFirst
