Selenium D220Ti-16 1" Titanium Horn Driver 16 Ohm 1-3/8"-18
Brand:|Model: D220Ti-16|Part # 264-272
Selenium's D220Ti-16 is a high quality compression driver offering excellent efficiency and low distortion. It is recommended for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms.
Comparable Items In Stock:
Part # 264-272
  • Titanium diaphragm for durability and extended HF response
  • Optimized phase plug eliminate phase cancellation problems
  • High-temperature voice coil materials ensure reliability
  • Smooth, extended frequency response
  • Easy diaphragm replacement
Selenium's D220Ti-16 is a high quality compression driver offering excellent efficiency and low distortion. It is recommended for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms. The D220Ti-16's diaphragm is formed from pure, rigid, light, and extremely thin titanium (0.025 mm). To avoid stress and distortion, the suspension has specially designed reinforcement. An injected-molded phase plug is optimized to eliminate undesirable phase cancellations. The ceramic magnetic assembly effectively concentrates flux in the gap, and highest motor strength efficiency is achieved through the use of FEA (Finite Element Analysis). A voice coil manufactured in CCAW (Copper Clad Aluminum Wire) and wound on a polyimide former assures great stability and thermal resistance, and the moving assembly has a perfect auto-centering characteristic that makes replacement easy if required. Standard 1-3/8"-18 TPI screw-on mounting.
Specifications: • Power handling: 80 watts RMS/160 watts program (with recommended 2,000 Hz, 12 dB/octave crossover) • VCdia: 1.7" • Throat diameter: 1" • Impedance: 16 ohms • Frequency response: 1,000-21,000 Hz (no crossover) • SPL: 109 dB 2.83V/1m • Magnet weight: 24 oz. • Dimensions: Overall diameter: 4.53", Depth: 2", 2.75" including threaded "nose".
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialTitanium
  • Impedance16 ohms
  • Power Handling (RMS)80 Watts
  • BrandSelenium
  • ModelD220Ti-16
  • Part Number264-272
  • UPC7896359519705
  • Product CategoryHorn Drivers
    (12 Reviews)
  • Weight4 lbs.
View similar products to the Selenium D220Ti-16 1" Titanium Horn Driver 16 Ohm 1-3/8"-18
in the Horn Drivers product category.
