Selenium D220Ti 1" Titanium Horn Driver 8 Ohm 1-3/8"-18
Brand:|Model: D220Ti-8|Part # 264-270
Selenium's D220Ti-8 is a high quality compression driver offering excellent efficiency and low distortion. It is recommended for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms.
List Price$62.20
You Save20%
Part # 264-270
  • Titanium diaphragm for durability and extended HF response
  • Optimized phase plug eliminate phase cancellation problems
  • High-temperature voice coil materials ensure reliability
  • Smooth, extended frequency response
  • Easy diaphragm replacement
  • D220Ti is compatible with any Selenium horn with model number ending in "25"
  • Standard 1-3/8"-18 TPI screw-on mounting
The Selenium D220Ti-8 horn driver's diaphragm is formed from pure, rigid, light, and extremely thin titanium (0.025 mm). To avoid stress and distortion, the suspension has specially designed reinforcement. An injected-molded phase plug is optimized to eliminate undesirable phase cancellations.
The D220Ti-8's ceramic magnetic assembly effectively concentrates flux in the gap, and highest motor strength efficiency is achieved through the use of FEA (Finite Element Analysis). A voice coil manufactured in CCAW (Copper Clad Aluminum Wire) and wound on a polyimide former assures great stability and thermal resistance, and the moving assembly has a perfect auto-centering characteristic that makes replacement easy if required. Standard 1-3/8"-18 TPI screw-on mounting.
Specifications: • Power handling: 80 watts RMS/160 watts program (with recommended 2,000 Hz, 12 dB/octave crossover) • VCdia: 1.7" • Throat diameter: 1" • Impedance: 8 ohms • Frequency response: 1,000-21,000 Hz (no crossover) • SPL: 109 dB 2.83V/1m • Magnet weight: 24 oz. • Dimensions: Overall diameter: 4.53", Depth: 2", 2.75" including threaded "nose".
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • BrandSelenium
  • ModelD220Ti-8
  • Part Number264-270
  • UPC7896359515905
  • Product CategoryHorn Drivers
    (109 Reviews)
  • Weight4 lbs.
View similar products to the Selenium D220Ti 1" Titanium Horn Driver 8 Ohm 1-3/8"-18
in the Horn Drivers product category.
