Selenium 15PW6-SLF 15" PA Woofer Speaker
Brand:|Model: 15PW6-SLF|Part # 264-464
The Selenium 15PW6 15" PA speaker is a high-power woofer with workhorse reliability and a tight, well-defined sound signature. It performs well in bass guitar rigs, pro sound reinforcement low frequency cabinets, and stage monitors.
  • Smooth response, thanks to long fiber pulp cone and impregnated fabric surround
  • FEA-optimized magnet maximizes output and reduces distortion
  • Extremely durable reinforced and epoxy coated stamped steel frame
  • Super-reliable high-temp copper wire voice coil on polyimide former
  • Engineered for PA woofer systems, stage monitors, and bass guitar amps
The Selenium 15PW6 15" PA woofer brings 400 watts RMS power handling and a solid bass punch to professional sound reinforcement system applications.
A lightweight long fiber pulp cone and newly designed impregnated fabric surround ensure the speaker's moving parts assembly is controlled and resilient. Tonal quality is tight, articulate, and low in distortion, particularly in the bass and lower midrange frequencies.
The 15PW6's high-temp copper wire voice coil is wound on a durable polyimide former, guaranteeing maximum heat resistance and excellent mechanical strength. A reinforced and epoxy coated stamped steel frame withstands harsh handling and tough environments. The hefty 88 oz. ceramic ferrite magnet provides high motor strength, assisted by Finite Element Analysis (FEA) optimization.
Selenium's 15PW6 15" speaker is ready to go to work in nightclubs, small theaters and auditoriums, musical instrument amplifiers, and stage monitors.
  • Nominal Diameter15"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Magnet Weight87.8 oz.
  • Resonant Frequency (Fs)37 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)1.58 mH
  • Mechanical Q (Qms)17.35
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)7.13 ft.³
  • Mechanical Compliance of Suspension (Cms)0.22 mm/N
  • BL Product (BL)17 Tm
  • Diaphragm Mass Inc. Airload (Mms)83g
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)860 cm²
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter15"
  • Baffle Cutout Diameter13.78"
  • Depth6.46"
  • # Mounting Holes8
  • Sealed Volume2.41 ft.³
  • Sealed F372 Hz
  • Vented Volume6.15 ft.³
  • Vented F339 Hz
  • BrandSelenium
  • Model15PW6-SLF
  • Part Number264-464
  • UPC7896359512119
    (1 Reviews)
  • Weight18.1 lbs.
View similar products to the Selenium 15PW6-SLF 15" PA Woofer Speaker
