Selenium 12MG1400 12" Woofer / Midbass Speaker
Brand:|Model: 12MG1400|Part # 264-468
A perfect balance of accuracy and high efficiency is achieved by the Selenium 12MG1400 12" Woofer/Midbass Speaker.
  • Designed for concert-level PA midbass applications
  • Massive 121 oz. magnet provides high BL factor (motor strength)
  • Low mass aluminum wire 4" voice coil on polyimide former
  • Extremely efficient—delivers high SPL with minimal power input
  • Long fiber pulp cone and impregnated double half-roll fabric surround for smooth response
  • Strong cast aluminum frame with epoxy coating
The Selenium 12MG1400 12" Woofer/Midbass Speaker is capable of producing high SPL midrange output when deployed in professional PA systems. Working equally well in both direct radiating and horn loaded enclosures, the 12MG1400's large ceramic ferrite motor and low mass 4" diameter aluminum voice coil contribute to the driver's high efficiency. A long fiber pulp cone and impregnated double half-roll fabric surround couple the motor to the air load, ensuring great dynamics and smooth response.
The 1,400 watt program power rating is achieved through the use of a polyimide voice coil former, high-temperature adhesives, and a large, tapered central vent in the pole piece. The entire assembly of moving parts is kept in perfect alignment by a cast aluminum and epoxy-coated frame.
  • Nominal Diameter12"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance8 ohms
  • Frequency Response150 to 4,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight121.3 oz.
  • Resonant Frequency (Fs)75 Hz
  • DC Resistance (Re)5.3 ohms
  • Voice Coil Inductance (Le)0.54 mH
  • Mechanical Q (Qms)10.76
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.55
  • Compliance Equivalent Volume (Vas)1.2 ft.³
  • Mechanical Compliance of Suspension (Cms)0.6 mm/N
  • BL Product (BL)16.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)62g
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.28"
  • Baffle Cutout Diameter11"
  • Depth4.65"
  • # Mounting Holes8
  • Sealed Volume1.04 ft.³
  • Sealed F3109 Hz
  • Vented Volume2.32 ft.³
  • Vented F353 Hz
  • BrandSelenium
  • Model12MG1400
  • Part Number264-468
  • UPC7896359515141
  • Weight23.48 lbs.
View similar products to the Selenium 12MG1400 12" Woofer / Midbass Speaker
