299-085_ALT_0
299-085_ALT_1
299-085_ALT_2
SAS Bazooka 10" Subwoofer Speaker 8 Ohm
Brand:|Part # 299-085
Designed for optimum performance in sealed enclosures intended for mobile audio or home subwoofer systems, this SAS Bazooka 10" speaker is a great choice for replacement or projects.
Part # 299-085
  • Strong stamped steel chassis with rear gasket for airtight front mounting
  • Paper cone with heavy duty foam edge provides generous, linear excursion
  • High temp 1-1/2" 4-layer copper voice coil on black anodized aluminum former
  • Large ceramic ferrite magnet with bumped back plate and extended pole piece
  • Very efficient—more output with less power
  • Perfect match for sealed enclosures in mobile audio applications
This SAS Bazooka WF1081.5 driver is an extremely well constructed 10" subwoofer designed to produce massive amounts of deep bass and handle plenty of abuse. It features the small engineering and manufacturing details that increase durability and power handling while still delivering all the low frequency response you need.
In addition to the bumped back plate, extra clearance is provided between the cone apex and the magnet top plate to avoid mechanical failure due to bottoming out the black anodized aluminum voice coil former. An oversized foam half roll surround keeps the cone in alignment while still permitting the excursion necessary to deliver a big kick, track after track. Buyout, limited quantities.
Specifications: *Power handling: 100 watts RMS/200 watts max *VCdia: 1-1/2" *Le: 2.80 mH *Impedance: 8 ohms *Re: 7.71 ohms *Frequency response: 35-1,500 Hz *Fs: 42.4 Hz *SPL: 90 dB 1W/1m *Vas: 1.78 cu. ft. *Qms: 4.08 *Qes: 0.59 *Qts: 0.52 *Xmax: 5 mm *Dimensions: Overall diameter: 10-1/8", Cutout diameter: 9-1/8", Depth: 4-3/4".
  • Nominal Diameter10"
  • BrandFactory Buyouts
  • Part Number299-085
  • UPC844632095030
    (5 Reviews)
  • Weight6.7 lbs.
View similar products to the SAS Bazooka 10" Subwoofer Speaker 8 Ohm
