Sanus WFA54mo Woodbrook 54" 7-Shelf AV Cabinet Mocha
Brand:|Model: WFA54MO|Part # 240-8884
The Sanus Foundations Woodbrook Series WFA54 is a single-wide seven-shelf mocha AV cabinet with six internal shelves.
  • Shelves can be adjusted to accommodate any size AV system
  • Concealed venting allows heated air to flow out the top while drawing in cool air through bottom
  • Hardwood frame is strong and solid for optimum acoustics
  • Enclosed architecture conceals an entire AV system for a clean look
  • Versatile line includes glass and wood door panels for a customizable design
  • Wire management channel helps keep cables concealed and organized
The Sanus Foundations Woodbrook Series WFA54 is a single-wide seven-shelf mocha AV cabinet with six internal shelves. Its contemporary design using Grade A hardwood and MDF virtually eliminates resonance. Sanus’ unique convection cooling system allows heated air to escape as cooler air is drawn in, keeping AV components at a proper temperature. Removable glass and wood door inserts allow total flexibility in cabinet design. Features include locking adjustable shelves, an extra-large wire channel and furniture-grade hinges. One tall door with glass insert and one small door with wood insert are included.
Specifications: • Overall dimensions: 23.75" W x 53.25" H x 23.75" D (60.33 x 135.26 x 60.33 cm) • Top shelf dimensions: 23.75" W x 23.75" D (60.33 x 60.33 cm) • Top shelf capacity: 105 lbs. (45.45 kg) • Middle shelf dimensions: 19.25" W x 19.25" D (48.90 x 48.90 cm) • Middle shelf capacity: 60 lbs. (27.27 kg) • Bottom shelf dimensions: 19.25" W x 19.25" D (48.90 x 48.90 cm) • Bottom shelf capacity: 100 lbs. (45.45 kg).
  • TypeFloor-standing
  • BrandSanus
  • ModelWFA54MO
  • Part Number240-8884
  • UPC793795350473
  • Product CategoryTV / AV Stands & Component Shelves
  • Weight124 lbs.
View similar products to the Sanus WFA54mo Woodbrook 54" 7-Shelf AV Cabinet Mocha
in the TV / AV Stands & Component Shelves product category.
