Sanus VMT35-B1 Tilting TV Wall Mount 26"-40"
Brand:|Model: VMT35-B1|Part # 185-3541
Sanus TV mounts are a cut above the competition, with superior looks, function, and ease of installation. The VMT35 is ready to mount most TVs 26"-40" and provides optional tilt for better viewing from below the height of the mount.
Part # 185-3541
  • TV bracket snaps into place on wall plate for safe, secure mounting
  • Rail-based design allows the bracket to slide on the wall plate for perfect positioning
  • Height and leveling adjustments are easy to adjust after mounting
  • Included hardware is labelled for quick, straightforward assembly and mounting
Sanus TV mounts are engineered to be the very best, and the very easiest to install. The VMT35 is no different. If you can't find two studs for mounting, just one will suffice. The mount will slide on the wall plate to allow the perfect positioning. Once installed, Sanus' trademarked Pro Set technology allows for final leveling and height adjustments. Fits most TVs between 26" and 40". Consult your TV's user manual for weight and VESA pattern information to be sure.
Specifications: • Dimensions: 22" W x 11.81" H x 2.25" D • Supported VESA sizes: Up to 400 x 300 • Tilt: 10.00° /-10.00° • Maximum TV weight: 80 lbs.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity20" to 29",30" to 39",40" to 49"
  • BrandSanus
  • ModelVMT35-B1
  • Part Number185-3541
  • UPC793795524911
  • Product CategoryTV Mounts & Brackets
  • Weight9.3 lbs.
View similar products to the Sanus VMT35-B1 Tilting TV Wall Mount 26"-40"
in the TV Mounts & Brackets product category.
