Sanus VMPR1B Universal Projector Mount Black
Brand:|Model: VMPR1B|Part # 185-470
The VMPR1 mount provides a unique, simplified method of mounting a projector. The low profile design offers independent adjustment for roll (±6°), pitch (±30°), and yaw (±15°). It also holds its position for quick lamp changes and easy filter cleaning without changing position.
List Price$149.99
You Save26%
$110.49
Part # 185-470
  • Professional grade construction
  • Independent adjustments make aiming easy
  • Universal mount fits nearly all projectors
  • Sleek design with decorative covers
The VMPR1 mount provides a unique, simplified method of mounting a projector. The low profile design offers independent adjustment for roll (±6°), pitch (±30°), and yaw (±15°). An adjustable height feature maintains proper ventilation, and holds its position for quick lamp changes and easy filter cleaning without changing position. Supports up to 50 lbs. and will fit 95% of the projectors on the market. Also available in silver. Dimensions: 12" to 18" W x 12" to 18" D x 4" to 4-3/4" H.
  • BrandSanus
  • ModelVMPR1B
  • Part Number185-470
  • UPC793795360489
  • Product CategoryProjector Mounts
    (7 Reviews)
  • Weight4 lbs.
View similar products to the Sanus VMPR1B Universal Projector Mount Black
in the Projector Mounts product category.
Sanus VMPR1B Universal Projector Mount Black is rated 4.7143 out of 5 by 7.
Rated 4 out of 5 by from Nice projector mount...but takes a lot of work to get everything straight and level.
Date published: 2009-07-21
Rated 4 out of 5 by from Good overallGood overall product with a couple small exceptions. The included threaded extension had the threads flattened (for safety?) but the end result was it would not mate with standard threaded pipe from the hardware store, nor did it appear to mesh well with the threads on the included brackets, so if you need an extension, buy one at the hardware store, along with a can of satin black paint. Other than that, the install went smoothly, and everything functioned as advertised. I especially like the quick disconnect feature, though (in my case) I would still have to detach the bracket from the projector to install a new bulb.
Date published: 2009-06-04
Rated 5 out of 5 by from Great productEasy, straightforward installation, fit my projector, black color was important to blend in. Very nice product, even if I could not get the plastic covers to fit (did not need them anyway). Hgihly recommended at this price.
Date published: 2009-01-02
Rated 5 out of 5 by from Good Mount!I have used dozens of these mounts through PE in the past years , A great product for school installations
Date published: 2008-07-02
Rated 5 out of 5 by from Great Product OverallI have now installed 3 of these and it is the easiest of all the other projectors I have installed. Great product, easy to use.Holds position when projector is angled, too, which is a plus.
Date published: 2008-02-08
Rated 5 out of 5 by from Good and EasyIt was easy to setup and attach to the projector. No problems which was a blessing to be sure. Barely had to look at the directions. I have used these in a couple church and school installs now.
Date published: 2007-12-27
  • 2016-02-13T07:00CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_185-470, PRD, sort_mostRecent
What size diameter pipe can I buy at the hardware store to use as an extension
Asked by: BigE
This pipe has an external diameter of 1.35" but it will likely be called a 1" pipe at the store, based on inside dimensions. The thread is 11-1/2 TPI.
Date published: 2014-08-26
  • 2016-02-13T07:58CST
  • loc_en_US, sid_185-470, PRD, sort_recentQuestionsFirst
