Sanus VLT16-B1 Super Slim Tilting TV Mount 51" - 80"
Brand:|Model: VLT16-B1|Part # 185-3618
This Sanus TV mount takes super slim to the next level. Now you can position a flat screen TV up to 80" on a mount less than one inch thick. Post-installation tilt, height and leveling adjustments means your television can easily be set to the perfect viewing angle.
List Price$169.99
You Save25%
Part # 185-3618
  • Easily mount larger televisions 51" – 80"
  • ClickStand technology holds TV away from wall for easy cable installation
  • Supports televisions up to 125 lbs.
  • Mounting holes designed for 16" or 24" studs
The Sanus VLT16-B1 combines all the best technology Sanus has to offer in a super slim design. Virtual Axis™ technology means you to adjust the tension of the mount which makes tilting you TV effortless. Angle your television downward up to 10° to obtain an optimal viewing angle. The ProSet™ feature enables fine adjustments to the height and leveling of your television post-installation, which takes off all the pressure of getting it exactly right the first time. Have you ever mounted a TV, gotten it exactly how you want it, only to realize you can't access the cable inputs on the back? ClickStand™ technology means you never have to worry about that. The ClickStand will hold your TV away from the wall while still mounted, allowing for easy access to all the cable inputs on the back of your TV.
All these features plus universal mounting and 26 supported VESA patterns means the VLT16 creates a perfect mounting solution for your high-end flat screen television.
Specifications: • Dimensions: 29.30" W x 17.30" H x 0.82" D • TV size range: 51" - 80" • Maximum TV weight: 125 lbs. • Mounting pattern: Universal • Tilt: 10° - 0°.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity50" to 59",60" to 69",70" and up
  • BrandSanus
  • ModelVLT16-B1
  • Part Number185-3618
  • UPC793795527486
  • Product CategoryTV Mounts & Brackets
    (1 Reviews)
  • Weight9.1500 lbs.
View similar products to the Sanus VLT16-B1 Super Slim Tilting TV Mount 51" - 80"
in the TV Mounts & Brackets product category.
