Sanus VLL10-B1 Super Slim Wall Mount for 32"-70" LCD
Brand:|Model: VLL10-B1|Part # 185-3558
The VisionMount VLL10 Super Slim low-profile wall mount is designed to emphasize the sleek look of ultra-thin LCD, plasma and LED TVs by placing them just .67" from the wall. Universal mounting pattern fits virtually any 32" – 60" flat-panel TV up to 125 lbs.
Part # 185-3558
  • Super Slim low-profile mount places TV just .67" from wall to maximize its sleek, thin appearance
  • Universal TV brackets fit most LCD, LED and plasma TVs from 32" – 70"
  • Quick-release tabs stay hidden, but easily pull down to unlock TV from wall plate for cable access
  • Innovative ClickStand™ technology holds TV away from wall for easy cable access
  • Rail design allows TV to shift left and right for perfect placement, even with off-center studs
The VisionMount VLL10 Super Slim low-profile wall mount is designed to emphasize the sleek look of ultra-thin LCD, plasma and LED TVs by placing them just .67" from the wall. The VLL10 features exclusive ClickStand™ technology, which holds the bottom of the TV away from the wall for easy cable access without removing the TV from the mount. Convenient quick-release tabs on the mounting brackets stay hidden, but easily pull down to unlock the TV from the wall plate for cable access. The VLL10 also allows lateral shift adjustment, allowing the TV to slide left and right on the wall plate so it’s positioned exactly where you want it, even with off-center wall studs. Wall plate mounting holes are designed to accommodate 16" or 24" studs. Universal mounting pattern fits virtually any 32" – 60" flat-panel TV up to 125 lbs.
Specifications: • Dimensions: 30.53" W x 17.49" H x 0.67" D (77.55 x 44.42 x 1.70 cm) • TV Size range: 32" - 60" (81.28 - 152.40 cm) • Maximum TV weight: 125 lbs. (56.82 kg) • Mounting pattern: Universal.
  • Mount TypeFixed
  • Mount StyleWall Mount
  • TV Capacity40" to 49"
  • BrandSanus
  • ModelVLL10-B1
  • Part Number185-3558
  • UPC793795521316
  • Product CategoryTV Mounts & Brackets
    (1 Reviews)
  • Weight7.3 lbs.
View similar products to the Sanus VLL10-B1 Super Slim Wall Mount for 32"-70" LCD
in the TV Mounts & Brackets product category.
