Sanus VF5023-B1 3 Shelf Wall Mount 31.5" Tall
Brand:|Model: VF5023-B1|Part # 240-8856
The Sanus Foundations Vertical Series VF5023 is an AV component system that mounts directly under a wall-mounted TV for a sleek, streamlined look.
  • Shelves can be adjusted to accommodate any size AV system
  • Wire management system helps keep cables concealed and organized
  • Interchangeable black glass and wood back panels match any décor
  • Extruded aluminum wall brackets simplify installation by providing lateral & vertical adjustments
  • Back panels are slightly offset from wall to easily conceal cables, surge protectors or wall outlet
  • Assembly hardware included
The Sanus Foundations Vertical Series VF5023 is an AV component system that mounts directly under a wall-mounted TV for a sleek, streamlined look. Specially designed brackets simplify installation by providing both lateral and vertical adjustment, even after hanging. Cable management channel easily routes cabling behind unit. The VF5023 includes two interchangeable back panels in black glass or mocha-finished wood to match any home dÉcor. Back panels are easily removed for easy access to wall outlets and surge protector. Three thick tempered-glass shelves support up to 75 lbs. each and can be vertically adjusted to accommodate any AV component arrangement.
Specifications: • Overall dimensions: 38.38" W x 31.51" H x 20.83" D (97.49 x 80.04 x 52.91 cm) • Top shelf dimensions: 38" W x 21" D (96.52 x 53.34 cm) • Top shelf capacity: 75 lbs. (34.09 kg) • Middle shelf dimensions: 38" W x 21" D (96.52 x 53.34 cm) • Middle shelf capacity: 75 lbs. (34.09 kg) • Bottom shelf dimensions: 38" W x 21" D (96.52 x 53.34 cm) • Bottom shelf capacity: 75 lbs. (34.09 kg).
  • TypeWall-mount
  • BrandSanus
  • ModelVF5023-B1
  • Part Number240-8856
  • UPC793795490032
  • Product CategoryTV / AV Stands & Component Shelves
    (1 Reviews)
  • Weight111 lbs.
View similar products to the Sanus VF5023-B1 3 Shelf Wall Mount 31.5" Tall
in the TV / AV Stands & Component Shelves product category.
