Sanus VF2022-B1 2 Shelf Double Column Wall Mount 47" Wide
Brand:|Model: VF2022-B1|Part # 240-8852
The Sanus Foundations Vertical Series VF2022 is a double-column AV component system that mounts directly under wall-mounted TVs for a sleek, streamlined look.
  • Strong tempered-glass shelves can be vertically adjusted to accommodate any AV arrangement
  • Cable management system organizes cables, while joiners conceal & routes cables into cable tunnels
  • Separate channels for power and signal cables prevent interference
  • Post-installation height adjustment feature ensures entire unit is at perfect height
  • Columns easily attach to wall brackets for trouble-free installation; hardware included
The Sanus Foundations Vertical Series VF2022 is a double-column AV component system that mounts directly under wall-mounted TVs for a sleek, streamlined look. Its two columns are vertically adjustable for perfect alignment under a wall-mounted TV, even after hanging. Each column features two integrated channels with over four square inches of space for easy power cable and signal wire routing. Thick tempered-glass shelves support up to 50 lbs. each and can be vertically adjusted to accommodate any AV component arrangement.
Specifications: • Overall dimensions: 39" W x 21.25" H x 18" D (99.06 x 53.98 x 45.72 cm) • Top shelf dimensions: 39" W x 18" D (99.06 x 45.72 cm) • Top shelf capacity: 50 lbs. (22.73 kg) • Bottom shelf dimensions: 39" W x 18" D (99.06 x 45.72 cm) • Bottom shelf capacity: 50 lbs. (22.73 kg).
  • TypeWall-mount
  • BrandSanus
  • ModelVF2022-B1
  • Part Number240-8852
  • UPC793795490025
  • Product CategoryTV / AV Stands & Component Shelves
    (1 Reviews)
  • Weight100 lbs.
View similar products to the Sanus VF2022-B1 2 Shelf Double Column Wall Mount 47" Wide
in the TV / AV Stands & Component Shelves product category.
