Sanus UF26 Foundations Ultimate 26" Speaker Stand Pair
Brand:|Part # 240-842
The Foundations Ultimate Series UF26 is a 26" stand for medium-to-large bookshelf speakers up to 35 lbs.
Part # 240-842
  • Adjustable carpet spikes and screw-in polyester feet add stability on any surface
  • Choose from brass isolation studs or neoprene speaker pads for stable speaker isolation
  • Integrated Poron® rings isolate speaker from vibrations in floor
  • Pillars can be filled with shot or sand for added stability
  • Spackled gray finish blends subtly into most any decor
The Foundations Ultimate Series UF26 is a 26" stand for medium-to-large bookshelf speakers up to 35 lbs. Its stable triangular base is made of minerals, resins and glass for superior resonance damping. Three textured gray steel pillars support a 6" x 6-1/2" steel top plate with brass speaker isolation studs for a stable, non-slip surface. Pillars can be filled with shot for added mass and have damping rings at both ends to effectively isolate vibrations. Base includes carpet spikes and rubber pads for use on any floor surface.
Specifications: • Dimensions: 13" W x 26" H (33.02 x 66.04 cm) • Maximum speaker weight: 35 lbs. (15.91 kg).
  • BrandSanus
  • Part Number240-842
  • UPC793795300263
  • Product CategorySpeaker Stands
  • Unit of MeasurePR
    (1 Reviews)
  • Weight37.6 lbs.
View similar products to the Sanus UF26 Foundations Ultimate 26" Speaker Stand Pair
in the Speaker Stands product category.
