Sanus SF213-B1 Full Motion LCD Wall Mount up to 27" Monitor
Brand:|Model: SF213-B1|Part # 185-3546
The VisionMount SF213 is a full-motion wall mount for TVs up to 27" and 45 lbs. Fits VESA 200 x 100, 100 x 100 and 75 x 75 patterns.
Part # 185-3546
  • Virtual Axis™ provides smooth tilt motion with touch of a fingertip
  • Full motion mount extends, pans, tilts and swivels for easy viewing anywhere in a room
  • VESA TV bracket fits 200 x 100, 100 x 100 and 75 x 75 hole patterns
  • Built-in cable management system protects and conceals cables
The VisionMount SF213 is a full-motion wall mount for TVs up to 27" and 45 lbs. Virtual Axis™ allows smooth, effortless tilt motion with the push of a finger, making it easy to reduce glare and find the perfect TV angle at any height. Full motion allows maximum flexibility — extend, tilt and swivel your TV up to 13" from the wall in every direction for easy viewing from any seat in a room. Post-installation level adjustment allows the TV to “roll” up to 1º clockwise and counterclockwise to ensure it is perfectly level. In-arm cable channel conceals and routes cables for a clean appearance. Fits VESA 200 x 100, 100 x 100 and 75 x 75 patterns.
Specifications: • Dimensions: 8" W x 9" H x 13" D max, 3" D min (20.32 x 22.86 x 33.02, 7.62 cm) • TV Size range: 9" - 27" (22.86 - 68.58 cm) • Maximum TV weight: 45 lbs. (20.45 kg) • Mounting pattern: VESA 100 x 100, VESA 200 x 100, VESA 75 x 75 • Tilt: 15°/-15° • Swivel: 90°/-90° • Roll: 1°/-1°.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV Capacity30" to 39"
  • BrandSanus
  • ModelSF213-B1
  • Part Number185-3546
  • UPC793795363572
  • Product CategoryTV Mounts & Brackets
  • Weight4.6 lbs.
View similar products to the Sanus SF213-B1 Full Motion LCD Wall Mount up to 27" Monitor
in the TV Mounts & Brackets product category.
