Sanus PFFP2b Three-Shelf Flat-Panel/Plasma TV Stand
Brand:|Model: PFFFP2B|Part # 240-8838
The Sanus Foundations Flat Panel Series PFFP2b is a three-shelf flat-panel TV pedestal with sleek platinum lines and a custom-blended silver finish to offer a striking look that complements modern AV gear.
  • Tempered-glass shelves with polished edges are strong and stylish
  • Aluminum accents give a sleek, light feel to this solid piece
  • Assembly hardware included
  • Innovative column design is a great alternative to wall mounting
  • Wire management system helps keep cables concealed and organized
The Sanus Foundations Flat Panel Series PFFP2b is a three-shelf flat-panel TV pedestal with sleek platinum lines and a custom-blended silver finish to offer a striking look that complements modern AV gear. High-quality construction and open architecture maximize airflow and provide the enhanced strength needed to handle even the largest televisions. Innovative aluminum column supports large TVs with grace. Features include a large wire management channel and two sleek, black tempered-glass shelves.
Specifications: • TV Diagonal min/max: 30" - 50" (76.20 - 127 cm) • Overall dimensions: 43.25" W x 48.75" H x 23.25" D (109.86 x 123.83 x 59.06 cm) • Product weight capacity: 130 lbs. (59.09 kg) • Top shelf dimensions: 24.25" W x 16.50" D (61.60 x 41.91 cm) • Top shelf capacity: 50 lb (22.73 kg) • Middle shelf dimensions: 30.25" W x 16.50" D (76.84 x 41.91 cm) • Middle shelf capacity: 50 lbs. (22.73 kg) • Bottom shelf dimensions: 43.25" W x 23.25" D 109.86 x 59.06 cm) • Bottom shelf capacity: 50 lbs. (22.73 kg) • Positive tilt: +12° • Negative tilt: -12° • Mounting pattern: Universal.
  • TypeFloor-standing
  • BrandSanus
  • ModelPFFFP2B
  • Part Number240-8838
  • UPC793795320070
  • Product CategoryTV / AV Stands & Component Shelves
  • Weight120 lbs.
View similar products to the Sanus PFFP2b Three-Shelf Flat-Panel/Plasma TV Stand
in the TV / AV Stands & Component Shelves product category.
