Sanus LT25b Tilting Wall LCD 32"-70" Mount
Brand:|Model: LT25B|Part # 185-3514
The VisionMount LT25 is a tilting wall mount for 30" – 60" flat-panel TVs. Sanus Systems’ Virtual Axis™ tilting technology provides effortless adjustment of viewing angle without the use of tools.
Part # 185-3514
  • Lateral shift allows TV to slide left & right for perfect TV placement, even with off-center studs
  • Virtual Axis™ technology offers effortless tilt motion without the use of tools
  • ProSet™ post-installation height/level adjustments ensure TV is perfectly positioned after install
  • ClickStand™ feature holds TV out from wall for easy cable installation
  • Surge suppressors and other accessories snap onto mount and are hidden behind TV
  • Open wall plate design provides generous space for cable management
The VisionMount LT25 is a tilting wall mount for 30" – 60" flat-panel TVs. Sanus Systems’ Virtual Axis™ tilting technology provides effortless adjustment of viewing angle without the use of tools. ProSet™ post-installation height and leveling adjustments ensure TVs are always perfectly positioned after hanging. The innovative ClickStand™ feature holds the TV away from wall for easy cable installation and maintenance, then snaps shut to secure the TV to the wall plate. The LT25 features an open wall plate design that provides ample room for cable routing, and ClickFit™ technology allows a surge protector to attach easily to the center of the mount, so it stays hidden yet easily accessible. The TV can also be shifted left and right on the wall plate for perfect placement, even with off-center studs. Extruded aluminum wall plate construction is strong and lightweight, making installation a breeze. Universal mounting pattern fits virtually any 30" – 60" flat-panel TV up to 175 lbs.
Specifications: • Dimensions: 30" W x 18.25" H x 3" D (76.2 x 46.36 x 7.62 cm) • TV size range: 30" - 60" (76.20 - 152.40 cm) • Maximum TV weight: 175 lbs. (79.55 kg) • Mounting pattern: Universal • Tilt: 8°/-10° • Roll: 2°/- 2°.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69",70" and up
  • BrandSanus
  • ModelLT25B
  • Part Number185-3514
  • UPC793795363398
  • Product CategoryTV Mounts & Brackets
  • Weight14.3 lbs.
View similar products to the Sanus LT25b Tilting Wall LCD 32"-70" Mount
in the TV Mounts & Brackets product category.
