Sanus JFV60-E1 Java Lowboy AV Cabinet Espresso
Brand:|Model: JFV60-E1|Part # 240-8790
The sturdy JFV60 supports up to 350 lbs. of AV equipment when the placed on the floor and up to 200 lbs. when mounted on the wall.
ORDER TODAY
Ships in 7-10 Business Days
List Price$529.99
You Save20%
ShippingTRUCK ONLY
$424.99
Part # 240-8790
  • Sliding glass doors give AV gear an enclosed look without blocking infrared remote control signals
  • Supports up to 200 lbs. when mounted on wall; supports up to 350 lbs. when placed on floor
  • Includes a steel back plate for mounting on wall and removable feet for placing it on floor
  • Rear cable management channels keep cables hidden and organized for a flawless appearance
The Sanus Foundations Java Series JFV60 can be placed on the floor or mounted on the wall, making it the most versatile AV cabinet on the market. This unique piece includes easily attachable feet for placement on the floor and a steel wall-mounting plate to accommodate 16" on-center wall studs. The sturdy JFV60 supports up to 350 lbs. of AV equipment when the placed on the floor and up to 200 lbs. when mounted on the wall. Sliding glass doors give AV gear an enclosed look without blocking infrared remote control signals, and lateral shift allows the unit to move left and right after hanging to ensure perfect placement. Rear cable management channels conceal and route cabling for a clean and flawless appearance.
Specifications: • Dimensions: 60.25" W x 18.25" H x 19.92" D (153.04 x 46.36 x 50.6 cm) • On-wall weight capacity: 200 lbs. (90.91 kg) • On-floor weight capacity: 350 lbs. (159.09 kg) • Top shelf dimensions: 60.24" W x 19.92" D (153.01 x 50.60 cm) • Top shelf capacity: 50 lbs. (22.73 kg) • Middle shelf dimensions: 56.93" W x 17.72" D (144.60 x 45.01 cm) • Middle shelf capacity: 50 lbs. (22.73 kg) • Bottom shelf dimensions: 56.93" W x 17.72" D (144.60 x 45.01 cm) • Bottom shelf capacity: 50 lbs. (22.73 kg).
  • TypeFloor-standing
  • BrandSanus
  • ModelJFV60-E1
  • Part Number240-8790
  • UPC793795520760
  • Product CategoryTV / AV Stands & Component Shelves
  • Weight144 lbs.
View similar products to the Sanus JFV60-E1 Java Lowboy AV Cabinet Espresso
in the TV / AV Stands & Component Shelves product category.
