Sanus ELM805-B1 Elements PowerBridge In-Wall Power System
Brand:|Model: ELM805-B1|Part # 240-8782
The Sanus Elements™ ELM805 PowerBridge® is an in-wall power and cable management system designed to simplify installation of cables and wiring behind wall-mounted flat-panel TVs.
List Price$119.99
Regular Price$84.99
You Save35%
Sale Price
$55.00
Part # 240-8782
  • Easily install in-wall cables and wiring behind flat-panel TVs and through wall
  • Route low voltage cables/wires through wall into AV components, surge protector or power conditoner
  • Color-coded outlets simplify installation without modifying existing circuit
  • Connect to local AC power source or surge protector, or use remotely in AV equipment room
The Sanus Elements™ ELM805 PowerBridge® is an in-wall power and cable management system designed to simplify installation of cables and wiring behind wall-mounted flat-panel TVs. This discreet system allows low voltage cables and wires to be routed through the wall and into AV components, surge protectors or power conditioners for a flawless home theater installation. Color-coded outlets simplify installation without modifying the existing circuit. Connect to a local AC power outlet or to use remotely in an AV equipment room. Includes 6 ft. heavy-gauge power wire. Non-metallic (NM) type 12-2 or 14-2 building electrical wire (best known as Romex®) is not included. Check with local and regional building code requirements before beginning installation.
PRODUCT SPECIFICATIONS
  • SizeIrregular
  • ConnectorsAC Outlet
  • FinishBlack
  • BrandSanus
  • ModelELM805-B1
  • Part Number240-8782
  • UPC793795500144
  • Product CategoryBulk Cable Wall Plates
  • Weight1.95 lbs.
View similar products to the Sanus ELM805-B1 Elements PowerBridge In-Wall Power System
in the Bulk Cable Wall Plates product category.
