Sanus ELM803-B1 Elements In-Wall Low Voltage Box
Brand:|Model: ELM803-B1|Part # 240-8780
The Sanus Elements ELM803 in-wall low voltage box helps to position a flat-panel TV as flush with the wall as possible, offering 56 cubic inches of space to hold cables and create a clean cavity in the wall.
  • Great accompaniment to Sanus mounts with or without ClickFit™ compatibility
  • In-wall box w/cable routing holes & single-gang low voltage pass-through inlet/oulet knockouts
  • Has 56 cubic inches of space to hold cables & create a clean cavity in wall for low profile mounts
  • Easy to install — simply fit in-wall box into clean opening behind any wall-mounted TV
The Sanus Elements ELM803 in-wall low voltage box helps to position a flat-panel TV as flush with the wall as possible, offering 56 cubic inches of space to hold cables and create a clean cavity in the wall. Great for use behind mounts with or without ClickFit™ compatibility, the ELM803 features cable routing holes and single-gang low voltage pass-through inlet/outlet knockouts for the ultimate in convenience. Simply fit the in-wall box into an opening behind any wall-mounted TV to route cables and wires into the wall for a seamless appearance.
  • BrandSanus
  • ModelELM803-B1
  • Part Number240-8780
  • UPC793795520456
  • Product CategoryLow Voltage Boxes & Mounting Brackets
  • Weight0.6 lbs.
