Clearance Item
240-8670_ALT_0
240-8670_ALT_1
Sanus CFAV34-CB1 34" 3-Shelf AV Stand Cherry and Black
Brand:| Model: CFAV34-CB1
The Sanus Foundations Component Series CFAV34 is a 34" wide three-shelf cherry and black AV stand with glass door inserts.
  • Shelves can be adjusted to accommodate any size AV system
  • Concealed venting allows heated air to flow out the top while drawing in cool air through the botto
  • Enclosed architecture conceals an entire AV system for a clean look
  • Wire management system helps keep cables concealed and organized
  • Removable back panels lift out effortlessly, allowing easy access to AV components for wiring
240-8670
Weight: 120 lbs.
The Sanus Foundations Component Series CFAV34 is a 34" wide three-shelf AV stand with glass door inserts. Its quick-release back panel features pre-cut cable openings and is easily removed, providing access to components for wiring and maintenance. Adjustable internal shelves isolate components from vibrations and can be placed at customized heights for any AV system arrangement. Durable hardwood construction and enclosed architecture hide away an entire AV system for a clean, contemporary look. Sanus’ unique convection cooling system allows heated air to escape through vents in the top as cooler air is drawn in through the bottom, keeping AV components at a proper temperature even with the doors shut. Features include a full-width cable management channel and removable carpet glides for easy mobility.
Specifications: • Product dimensions: 34.36" W x 28.07" H x 23.25" D (87.27 x 71.3 x 59.06 cm) • Top shelf dimensions: 34.50" W x 23.25" D (87.63 x 59.06 cm) • Top shelf capacity: 60 lbs. (27.27 kg) • Middle shelf dimensions: 30.50" W x 19.25" D (77.47 x 48.90 cm) • Middle shelf capacity: 50 lbs. (22.73 kg) • Bottom shelf dimensions: 30.50" W x 19.25" D (77.47 x 48.90 cm) • Bottom shelf capacity: 100 lbs. (45.45 kg).
  • TypeFloor-standing
  • BrandSanus
  • ModelCFAV34-CB1
  • Part Number240-8670
  • UPC793795400178
  • Product CategoryTV / AV Stands & Component Shelves
  • Weight120 lbs.
View similar products to the Sanus CFAV34-CB1 34" 3-Shelf AV Stand Cherry and Black
in the TV / AV Stands & Component Shelves product category.
Customer projects that include: Sanus CFAV34-CB1 34" 3-Shelf AV Stand Cherry and Black
