260-292_ALT_0
Round Speaker Terminal Cup 2-7/8" Satin Nickel Banana Binding Post
Brand:|Part # 260-292
Round recessed panel with satin nickel plated binding posts. Color coded. Accepts up to 8 gauge wire. Can also be used with dual banana plugs.
List Price$7.49
You Save27%
$5.50
Buy 10-49 $4.94
Buy 50+$4.25
Part # 260-292
Dimensions: • Overall size: 2-7/8, cutout: 1-7/8" • Includes gasket • Connectors accept 0.205" female disconnect terminals
  • BrandParts Express
  • Part Number260-292
  • UPC844632077500
  • Product CategoryTerminal Plates & Cups
    (9 Reviews)
  • Weight0.16 lbs.
View similar products to the Round Speaker Terminal Cup 2-7/8" Satin Nickel Banana Binding Post
in the Terminal Plates & Cups product category.
Round Speaker Terminal Cup 2-7/8" Satin Nickel Banana Binding Post is rated 4.3333 out of 5 by 9.
Rated 5 out of 5 by from Fits Bose 301 IIIThis product is a perfect fit to replace the spring clip speaker wire terminal hole on the Bose 301 III to convert to banana clip connections for my home theater rewiring. I've always hated spring clips, and I think the banana clips make a more reliable connection and are easier to work with.
Date published: 2015-01-09
Rated 4 out of 5 by from Pretty Much Only For Banana Plugs!!!Bought this to use on my Boston A70's, perfect fit, but use banana plugs, which is the reason I got them. Getting your fingers in there to tighten them is a real pain.
Date published: 2014-10-12
Rated 5 out of 5 by from Very well made product!I bought a pair of those terminals to replace the old ones. These terminals come with the gasket and were drop in replacement since the cut out was perfect. They are durable, simple to use and install, and also the quality is really good.
Date published: 2014-07-23
Rated 3 out of 5 by from A little difficult to useI have large hands and with 12 ga wire these posts (because they are recessed) are difficult to use. They are completely functional and work fine, just a little challenging to install/insert wire into. But once the wires are attached, there is little left to do so it is fine.
Date published: 2012-12-13
Rated 4 out of 5 by from decent low-cost binding post that accepts a dual-banana plugNo complaints at all, was as described on the site. In my application, it dropped straight in where the wimpy cheapo connector was. I would buy this again.
Date published: 2012-12-09
Rated 5 out of 5 by from Great ProductThese look good and feel nice and solid. Something about them makes my enclosure look really beefy lol.
Date published: 2012-02-22
  • 2016-02-09T06:29CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_260-292, PRD, sort_mostRecent
Do you just cut a circle out of your box to install these?
If so, what size hole?Also, should I put some silicone or something when I install it to seal it up?
Asked by: Mike985
yes. description lists 1 7/8" as cutout, but that is wrong. cut 2". silicone = bad idea. they come with a semi-rigid foam gasket that when fastened tight creates a seal.
Answered by: gothmandson
Date published: 2015-08-12
  • 2016-02-09T07:07CST
  • loc_en_US, sid_260-292, PRD, sort_recentQuestionsFirst
