BUYOUT
269-103_ALT_0
Round 4-1/2" Speaker Terminal Cup with Insulated Banana Binding Posts
Brand:|Part # 269-103
Don't waste power—and keep it safe! This ultra-high current capacity round recessed speaker terminal with clear polycarbonate insulators over nickel plated posts ensures a safe and efficient loudspeaker connection.
List Price$9.99
You Save75%
$2.50
Buy 10-99 $2.25
Buy 100+$1.88
Part # 269-103
  • Maximize your power transfer, safely
  • Attractive and highly conductive nickel-plated posts with full insulation
  • Accepts banana plugs or direct-connected wire up to 8 AWG
  • 3/8" hole with rubber plug for an optional jack, switch, or level control
  • Understated silver-gray finish
This ultra-high current capacity round recessed speaker terminal with clear polycarbonate insulators over nickel plated posts ensures a safe and efficient loudspeaker connection. A 1/4" opening on each terminal accepts up to 8 AWG wire connected directly, and the posts are also compatible with individual (not dual) banana plugs. This is a factory buyout from a famous manufacturer. We can't mention the name but the logo is embossed on the front. Includes a 3/8" hole with removable rubber plug, perfect for a jack, switch, or level control. Molded-in legend on dish and color coded band on terminals indicate polarity. Silver-gray finish over plastic.
Specifications: • Overall size: 4-1/2" diameter by 3/4" depth (not including terminal tabs) • Cutout: 3-5/8" diameter. Buyout, limited quantities.
  • BrandFactory Buyouts
  • Part Number269-103
  • UPC844632091698
  • Product CategoryTerminal Plates & Cups
    (12 Reviews)
  • Weight0.2 lbs.
View similar products to the Round 4-1/2" Speaker Terminal Cup with Insulated Banana Binding Posts
in the Terminal Plates & Cups product category.
Round 4-1/2" Speaker Terminal Cup with Insulated Banana Binding Posts is rated 4.5833 out of 5 by 12.
Rated 4 out of 5 by from LargeAs many of the other reviews state, these plates are quite large. I must have been looking at only the cost. No worries - I removed the cup from the binding posts and made some modifications to the speaker in order to make them work. (Bored both sides to make shallow indents so I could tighten the lock nut). Very attractive, and now I may have to take up smoking now that I have a few ash trays. Or, perhaps I will use them as nut holders.
Date published: 2015-04-23
Rated 5 out of 5 by from Speaker buildingI'm so happy with my products...I going to recommend it to all my family and friends...
Date published: 2014-11-26
Rated 4 out of 5 by from Well MadeNice quality and great price. Only issue for some is they protrude back about 1/2" so you cant use these on a enclosure that would hang on a wall. Otherwise a quality item for not much $$.
Date published: 2014-10-12
Rated 4 out of 5 by from Wish I Bought More...This is a great buy, I purchased 4 of them to refurb some old cabinets, and they do the job great. Cutting the right sized hole for these is a little difficult and the finish scratches off easily, but other than that, the posts are strong and well-made. On the other side, it does seem a little lacking in strength because there is only a little tab and a washer. But again, for the price, who cares!
Date published: 2014-07-17
Rated 4 out of 5 by from Nice Terminals but...a larger than 3-5/8"These terminals have a very sturdy, feel. Gave the product 4 instead of 5 stars because there is no gasket material, but at $2.50 each its certainly not the end of the world. They definitely live up the the quality of Mirage Speakers. However, the necessary cutout size is a tad bit larger than 3-5/8" diameter, like its specified. If you use 3-5/8" hole saw, like I did, you will have to squeeze these into the hole and hope to not crack the plate. They will fit VERY snug. You would be better cutting a 3-3/4" hole and sealing the back side with foam gasket tape.
Date published: 2014-06-11
Rated 5 out of 5 by from super valuegreat value..heavy duty, great looking and a great price
Date published: 2014-04-05
  • 2016-02-07T06:37CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_269-103, PRD, sort_mostRecent
How does the terminal hold the speaker wire?
Asked by: MrRaider
This is a standard binding post so it will accept bare wire, banana plugs or spade terminals.
Date published: 2014-05-21
  • 2016-02-07T07:37CST
  • loc_en_US, sid_269-103, PRD, sort_recentQuestionsFirst
