Rolls SX21 Tiny Two-Way Crossover w/Level Controls
Brand:|Model: SX21|Part # 245-1182
The SX21 by Rolls is a very simple 24dB/octave two-way frequency divider intended for small sound reinforcement applications. With Rolls quality and reliability, you know you're getting a name you can trust.
- Order Soon - Only 3 Left In Stock
List Price$120.00
You Save25%
$90.00
Part # 245-1182
  • 24 dB/octave rolloff
  • Mono 2-way crossover
  • Adjustable 50Hz - 2.5kHz crossover frequency
  • 1/4" unbalanced input and outputs
  • External power supply for low noise operation
The SX21 has 1/4" input, low and high output jacks, as well as input, crossover frequency, low and high output controls. It is powered by an included AC/DC adapter, and designed to be uncomplicated and effective for years to come. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Input impedance: 10k ohms • Output impedance: 1k ohms • Headroom: +10 dBV • Dimensions: 4.25" x 3.625" x 1.5" • Weight: 1 lb.
  • BrandRolls
  • ModelSX21
  • Part Number245-1182
  • UPC675889000214
  • Product CategoryActive Crossovers
    (3 Reviews)
  • Weight1.1 lbs.
View similar products to the Rolls SX21 Tiny Two-Way Crossover w/Level Controls
in the Active Crossovers product category.
Rolls SX21 Tiny Two-Way Crossover w/Level Controls is rated 4.3333 out of 5 by 3.
Rated 3 out of 5 by from Should Be StereoShould Be Stereo...perhaps they have one that is ?
Date published: 2015-07-06
Rated 5 out of 5 by from Superb ProductI need an electronic crossover for a sound system used on a Christmas parade float. I have used a Behringer CX-3400 in the past but it takes too long to figure out what pot to turn or what button to push!This little guy is SIMPLE, easy to adjust, and I like the labels on top of the box!And it sounds good too!
Date published: 2014-11-17
Rated 5 out of 5 by from Rolls SX21 Tiny Two-Way CrossoverI bought three of these in order to split signal between: (1) a Genz-Benz Shuttle 3.0T and an EV ZXA1-Sub (one SX21)(through the GB's effects loop) and (2) two Fishman SA 220s and two EV ZXA1-Subs (from the outputs of a Yamaha MG166CX miser). They work as advertised -- but I taped the power supply inputs to the crossovers after learning the "hard way" that that's what should be done.
Date published: 2014-02-19
  • 2016-02-11T06:44CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_245-1182, PRD, sort_mostRecent
can I use only the high pass side of this crossover? you know, and kinda like just run my bass amp full signal or somthing
Asked by: Anonymous the other one
Yes you can use only one output from this crossover.
Date published: 2014-08-11
will this accept a stereo 1/4 plug?
What I want to do is use this to split the frequencies <=180hz to an active sub and send everything else to a stereo amp to avoid distortion from the bookshelf speakers. Will I need to buy 2 (one for each channel) or will it filter and pass a stereo signal?
Asked by: he500guy
This is a mono crossover so it only uses unbalanced or mono connectors. Two will be required for a stereo pair.
Date published: 2013-10-01
  • 2016-02-11T07:40CST
  • loc_en_US, sid_245-1182, PRD, sort_recentQuestionsFirst
