245-1176_ALT_0
245-1176_ALT_1
245-1176_ALT_3
Rolls SL33b Mini Stereo Program Limiter with RCA & 3.5 mm In/Out
Brand:| Model: SL33b
The SL33 stereo limiter from Rolls provides smooth dynamics processing for both professional and consumer audio equipment. It has a very small footprint, and features 1/8" stereo and RCA inputs and outputs for easy connection to virtually any audio equipment.
  • 3.5mm stereo / RCA inputs and outputs
  • Automatic program limiting
  • Output level control and threshold control
  • Made in the USA
245-1176
Weight: 1 lbs.
IN STOCK
List Price$100.00
You Save32%
$67.67
Part # 245-1176
Since there is no audio level standard for consumer audio, the SL33 keeps the levels maintained evenly, providing you with a more comfortable listening environment. At the heart of the SL33 is a powerful compressor/limiter integrated circuit which provides automatic program limiting for unobtrusive and natural level control. A threshold control has been provided to set the level at which the process engages, and a makeup gain control offers output leveling. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Dimensions: 4" x 3.35" x 1.5" • Weight: 1 lb.
  • BrandRolls
  • ModelSL33b
  • Part Number245-1176
  • UPC675889000337
  • Product CategoryCompressor, Expander, Limiter, Gate
    (2 Reviews)
  • Weight1 lbs.
View similar products to the Rolls SL33b Mini Stereo Program Limiter with RCA & 3.5 mm In/Out
in the Compressor, Expander, Limiter, Gate product category.
Rolls SL33b Mini Stereo Program Limiter with RCA & 3.5 mm In/Out is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Rolls Stereo Program LimiterGreat Product. I purchased this item as a means to prevent over powering my Dayton Audio Pucks. I initially had difficulty calibrating this device because I'm new to limiters and there is little to know info only about this item in particular. After I was able to calibrate this correctly it works as described and protects m shakers from distorting/over powered when I crank up the home theater to levels that exceed the handling power of the audio pucks. I have my settings as follows... threshold at -10dB and make up gain at max.
Date published: 2014-03-11
Rated 4 out of 5 by from Works as advertised...almost!Unit does a good job of compressing signals above the set threshold, but is not actually a limiter, which would clamp output at a finite limit. This is actually a good thing as you still have a little bit of dynamic range for a bit more realism than you would get using a hard limiter, but just not nearly as loud.However, the unit does produce a pop on turn-on/off, so it has to be powered up before everything, and shut off after everything.I do own other Rolls devices, and they are bulletproof. This one should be also.
Date published: 2013-03-19
  • 2015-06-03T07:22CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_245-1176, PRD, sort_mostRecent
Customer projects that include: Rolls SL33b Mini Stereo Program Limiter with RCA & 3.5 mm In/Out
