Rolls REQ315 Rack Mount Dual 15-Band Constant Q Graphic Equalizer 2U
Brand:|Model: REQ315|Part # 245-1148
If you need a hassle-free, easy to use equalizer, the REQ315 is for you. Flexible inputs/outputs, Constant Q filters, rock-solid construction, and straightforward design all add up to one winning product from a name you can trust: Rolls.
ORDER TODAY
Ships in 7-10 Business Days
List Price$325.00
You Save23%
$250.00
Part # 245-1148
  • XLR and 1/4" in/outs
  • Low cut and high cut filters
  • Passive bypass
  • Durable construction for years of service
The REQ315 two rack space graphic equalizer by Rolls is intended for room equalizing or sound shaping and the approximate frequency response curve can be seen graphically by the settings of the frequency controls. Recording and broadcasting studios, sound contractors and musicians will appreciate the low noise, straightforward design, and versatile signal control of the REQ315. The equalization filters in the REQ315 are constant bandwidth (Constant Q). The bandwidth of each individual filter is narrow enough to prevent unwarranted interaction between filters, yet wide enough to produce exactly the type of correction curve demanded by even the most unusual acoustic surroundings.
Specifications: • Frequency response: 20 - 20,000 Hz • Range: +6dB or +12 dB (selectable) • Maximum input level +22 dB (balanced), +15dB (unbalanced) • Maximum output level +22 dB (balanced), +15dB (unbalanced) • THD + Noise: 0.01% • Signal-to-noise ratio: 110 dB below max level (A weighted) • Dimensions: 19" x 3.5" x 8.5" • Weight: 11 lbs.
  • BrandRolls
  • ModelREQ315
  • Part Number245-1148
  • UPC675889031508
  • Product CategoryEqualizers
  • Weight12 lbs.
View similar products to the Rolls REQ315 Rack Mount Dual 15-Band Constant Q Graphic Equalizer 2U
in the Equalizers product category.
