245-1134_ALT_0
Rolls RA235 Power Amplifier 1U Rack Mount 2 x 345W at 8 Ohms
Brand:| Model: RA235
If you're looking for a simple, reliable, and top quality power amplifier, look no further. The RA235 was designed with you in mind.
  • 1/4" and RCA inputs
  • Spring-loaded terminal outputs
  • Fault and thermal protection
  • Made in the USA
245-1134
Weight: 7.8 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$240.00
You Save22%
$184.93
Part # 245-1134
The RA235 by Rolls is a virtually indestructible single rack space amplifier intended for musicians and studio owners alike. The unit is ideal for home studio applications or wherever a no-nonsense, clean and efficient amplifier is required. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Frequency response: 5 - 40,000 Hz • Output power: 35W RMS x 2 (8 ohms/channel minimum load) • Signal-to-noise ratio: 114 dB @ 35W • Dimensions: 19" x 1.75" x 5" • Weight: 5.5 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)35 Watts
  • Output Channels2
  • Weight Range< 10 lbs.
  • BrandRolls
  • ModelRA235
  • Part Number245-1134
  • UPC675889023503
  • Weight7.8 lbs.
View similar products to the Rolls RA235 Power Amplifier 1U Rack Mount 2 x 345W at 8 Ohms
Rolls RA235 Rack Mount Professional Power Amplifier 8 Ohm 70 Watt 1U is rated 2.0 out of 5 by 1.
Rated 2 out of 5 by from Very cheaply designed, not worth the cost.I needed a good replacement for the famed Crown D45 in an industrial application. While the unit performs well enough, I was extremely disappointed by the quality. The inputs are unbalanced, the outputs are spring terminals (Really? Who does this? Pyramid, that's who...) and the amplifier itself is a pair of $5 LM3875 chip amps - no preamp stage, just a potentiometer feeding the amp directly. The clipping indicator is an LED wired into a voltage divider connected directly to the speaker output! It is mind-boggling how cut-rate the design is! It's really made me question the quality of Rolls as a result. Now I will be extra careful to look at the schematics they seem to provide in the owner's manuals.Rolls, this amplifier should sell for half the current cost to reflect its true value. It's not PE's fault in the least. This review is for the product, not the distributor.
Date published: 2014-05-28
Customer projects that include: Rolls RA235 Power Amplifier 1U Rack Mount 2 x 345W at 8 Ohms
