Rolls RA163 Rack Mount XLR Distribution Amp 8 Channel Mono/4 Channel Stereo
Brand:|Model: RA163|Part # 245-1126
Send your signal where you need it, and custom tailor the sound for your next install. Designed for crystal-clear sound and ease of use, the RA163 makes it easy.
  • Mono or stereo operation - mono input to eight mono outputs, or stereo input to four stereo outputs.
  • +20 dB gain switch
  • Balanced XLR inputs and outputs
  • Single rack space
The RA163 by Rolls is an eight channel mono, or four channel stereo distribution amplifier designed for the contractor / installer market. The outputs are designed to drive high-level balanced lines in a sound distribution system. The XLR jacks on the rear panel are for input and output, and each output may power more than one line. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Frequency response: 10 - 40,000 Hz (±1 dB) • THD: <0.008% • Signal-to-noise ratio: >90 dB • Maximum input level: +24 dBV • Maximum output level: +24 dB • Dimensions: 19" x 1.75" x 6.5" • Weight: 7 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs< 6
  • BrandRolls
  • ModelRA163
  • Part Number245-1126
  • UPC675889016307
  • Product CategoryCommercial Mic/Line Zone/Paging/BGM Mixers
  • Weight5.45 lbs.
View similar products to the Rolls RA163 Rack Mount XLR Distribution Amp 8 Channel Mono/4 Channel Stereo
in the Commercial Mic/Line Zone/Paging/BGM Mixers product category.
