Rolls DA134 4-Channel RCA Line Level Distribution Amplifier with 3.5 mm Input
Brand:|Model: DA134|Part # 245-1010
Designed for high-end line level audio distribution, the DA134 is a four-channel line level distribution amplifier with a small footprint.
ORDER TODAY
Ships in 7-10 Business Days
List Price$130.00
You Save25%
$98.00
Part # 245-1010
  • Expands the output of virtually any stereo device to multiple outputs
  • Front panel volume controls
  • Mono or stereo operation
  • Audiophile frequency response
  • Compatible with iPad, iPod, laptop, etc.
Featuring RCA and 1/8" inputs that can be switched mono or stereo, the DA134 will distribute a mono signal to eight outputs, or a stereo signal to four stereo outputs. The outputs are designed to provide line level signals, and more than one DA134 can be cascaded if more outputs are needed. The DA134 is the perfect solution anywhere high quality sound distribution is required. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Frequency response: DC - 60,000 Hz (±1 dB) • Input impedance: 10k ohms • Output impedance: 470 ohms • Maximum input level: +12 dBV • Maximum output level: +12 dB • Maximum gain: 20 dB • Signal-to-noise ratio: >90 dB • Crosstalk: -70 dB (stereo) • THD: <0.008% • Dimensions: 6.5" x 3.5" x 1.5" • Weight: 1.2 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • BrandRolls
  • ModelDA134
  • Part Number245-1010
  • UPC675889013405
  • Product CategoryLine Mixers
  • Weight2 lbs.
View similar products to the Rolls DA134 4-Channel RCA Line Level Distribution Amplifier with 3.5 mm Input
in the Line Mixers product category.
Would the correct setup of this unit be between a preamp and a power amp? And if yes, then could one hook up as many as four different power amps with this between the preamp and the poer amps?
Asked by: Rockster2U
yes. You can distribute 4 line level signals to 4 separate devices or amps if desired.
Answered by: TomI
Date published: 2015-02-10
Can the RCA outputs directly go to speakers or they need to feed into amplifier for the speaker? Thanks.
Asked by: AllanLee
This is a line level device only, so it will need to be fed into an amplifier first.
Date published: 2014-02-03
  • 2016-02-10T07:46CST
  • loc_en_US, sid_245-1010, PRD, sort_recentQuestionsFirst
