Right Angle Steel Bar Handle
Right Angle Steel Bar Speaker Cabinet Handle
Our right angle speaker cabinet handle is all you need for tall, heavy PA enclosures. Just tip back that massive bass bin and roll it away!
  • Mounts on upper rear corner for easy access
  • Painted steel construction won't crack or split like plastic
  • Works great on large, non-tilting cabinets, too
262-820
Weight: 1.75 lbs.
IN STOCK
List Price$11.99
You Save28%
$8.63
Buy 10-up$7.85
Part # 262-820
The handle you need for tall, heavy speaker enclosures! It mounts on the upper rear corner of tall, heavy, "tilt and roll" type speaker enclosures. This rugged all-steel handle features a recessed steel bar handgrip and durable black finish. Made of .035" steel and has twelve 7/32" mounting holes. Dimensions: 6-5/16" W x 6-1/2" H x 4-5/8" H x 3-3/8" D. Cutout dimensions: 4-5/8" W x 5-5/16" H x 3-1/2" H.
  • Construction MaterialSteel
  • Color / FinishBlack
  • BrandParts Express
  • Part Number262-820
  • UPC844632008047
  • Product CategoryHandles
    (5 Reviews)
  • Weight1.75 lbs.
View similar products to the Right Angle Steel Bar Speaker Cabinet Handle
in the Handles product category.
Right Angle Steel Bar Speaker Cabinet Handle is rated 4.6 out of 5 by 5.
Rated 5 out of 5 by from Nice HD corner handle for those hard to handle or move objectsWe used this handle in conjunction with the corner casters to facilitate movement of our large subwoofer cabinets.With this being a corner mounted device you might want to consider reinforcing the structure around it. We simply added 3/4" plywood to the corner area of the cabinet, glued and screwed down, to make the reinforcement.This handle did ring a little when the subs were operating at full power so we sprayed on truck bed liner to the reverse side of it after it is mounted. This did two things, stopped the ringing and sealed up the little air leaks around the handle and the casters we added to the cabinets.The entire selection of parts to perform this modification is available from PE.
Date published: 2013-09-30
Rated 5 out of 5 by from Great itemThis is by far the best handle iv ever installed on one of my cabs but the only thing I can ask for is it not to be so rounded at the handle part seeing that most of my cabs are right angles at 90•
Date published: 2013-08-07
Rated 4 out of 5 by from Sleek Design for Cabinet top mount handlesIf you need to make heavy cabinets mobile, a pair of these and a set of recessed casters will do nicly. This turns your cabinets into a hand truck and doubles as lifting handles if mounted with the long side orentated at the top of the cabinet. They don't protrude from the cabinets and they don't rattle. This is a must have feature in mobile speaker cabinets. Especially Bass Cabinets.
Date published: 2009-11-21
Rated 4 out of 5 by from solid handle that hasn't given out yet.I've used these a fair amount. I did ask PE if they could get these punched with d holes for mounting speakons directly into the handle. The way it's non-symmetric gives a perfect space for them. I think its a no brainer. No go they say. (how do you say that in chinese?) Anyway, I do find that the paint chips and flakes off a bit once they flex from torquing the screws. I haven't yet had to tackle a rust problem but we'll see. I find that the exact radius for a perfect fit is slightly larger than 1/2". I haven't sprung for a 9/16" roundover bit yet to see if they would work. But with some gasket material (weatherstrip) it works pretty well with a 1/2" roundover. Overall I like the design and haven't had any major issues.
Date published: 2008-12-08
Rated 5 out of 5 by from Tilt n Rollthese handle are greeat. work well with recessed casters just tilt & rol your speaker away. just make sure you do a 3/8" or 1/2" round over with your router so they fit perfectly
Date published: 2008-07-23
Is there any way we can get a side profile of this with measurments similar to that supplied by penn elcom?  Trying to finalize my cad drawing of my enclosure before I order.
Asked by: sine
Yes. Drawings for this and other Parts Express handles should be available for download by the end of business today. Look in the right-hand column under "Manuals/Resources."
Answered by: RussR
Date published: 2014-04-01
Customer projects that include: Right Angle Steel Bar Speaker Cabinet Handle
