Clearance Item
073-074_ALT_0
073-074_ALT_1
073-074_ALT_2
RGB 30 LED 1m Strip with Controller 12 VDC
Brand:| Model: DC-LE11124
Create your own custom lighting with this RGB LED strip. An 83 program LED controller is included and features 10 levels of speed control per program and individual LED control.
  • 30 RGB LEDs with an 83 function controller
  • Longer life and lower power consumption compared to rope lights
  • Weatherproof for outdoor use
073-074
Weight: 0.6 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$99.99
Regular Price$62.90
You Save24%
Sale Price
$48.00
Part # 073-074
This 1 meter (3.28 feet) RGB LED strip is built with bright surface mount RGB LEDs and offer amazing color density. Great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each strip.
The included controller creates amazing light shows featuring 83 different programs with 10 levels of speed control for each program. The controller features a phoenix-type quick disconnect connector for easy wiring. Simply connect a 12 VDC power supply (up to a 12 VDC, 1A power supply is recommended and sold separately) and go!
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 750 mA • Overall dimensions: 0.67" W x 39.36" L x 0.125" H (17 x 1000 x 3 mm).
RGB LED Specifications: • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
Note: This controller is designed to work with only this RGB LED strip. Other strips will not operate with this controller in the same manner.
  • BrandParts Express
  • ModelDC-LE11124
  • Part Number073-074
  • UPC844632093715
  • Product CategoryAccent & Party Lighting
  • Weight0.6 lbs.
View similar products to the RGB 30 LED 1m Strip with Controller 12 VDC
in the Accent & Party Lighting product category.
How can these strips be strung together?
The description says these strips can be connected together, but doesn't say how many can be connected, or how the patterns work with multiple strips. It implies that the strip does chase effects . . . how does this work, and do you offer additional strips to work with one controller?Also, I assume that the 5M strips can only be a single color at a time, while this strip can have multiple colors simultaneously.
Asked by: Orrin
They cannot be cascaded. Not designed for series operation. These are "smart" LED strips with controller ICs on the strip. You could add a strip in parallel [and DIY extension cable] as long as the power supply provides enough current. You might get away with the 1A supply suggested, or opt for the 2A supply to be sure.I do not see that single strips are available...
Answered by: Fanden
Date published: 2012-02-11
  • 2015-03-30T06:40CST
  • loc_en_US, sid_073-074, PRD, sort_recentQuestionsFirst
Customer projects that include: RGB 30 LED 1m Strip with Controller 12 VDC
