Clearance Item
073-068_ALT_0
073-068_ALT_1
073-068_ALT_2
073-068_ALT_3
073-068_ALT_4
073-068_ALT_5
073-068_ALT_6
073-068_ALT_7
073-068_ALT_8
073-068_ALT_9
RGB 12 LED 9.8" Strip Stick 12 VDC 2 Pcs.
Brand:| Model: DC-LE12124
Create your own custom lighting with RGB LED strip sticks.
  • Seven different color combinations
  • Longer life and lower power consumption compared to rope lights
  • Connects to LED remote control units for custom effects
  • Cut lines on circuit board for creating miniature segments
073-068
Weight: 0.1 lbs.
These LED strips are built with 12 bright surface mount RGB LEDs. Great for use as indoor strip lighting or illuminating a display case. Two 9.8" strips are included within this package to create a 19.6" long 24 RGB LED light strip. Connecting the two strips together is made quick and simple with one strip featuring a male connector and the other featuring a female connector.
Each strip stick has been marked with cut lines for creating a custom length strip, or up to eight miniature 2-7/16" strips with three RGB LEDs per section. Each section features four solder points (voltage +, green, red, and blue) to create one of seven different colors and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 3A power supply is recommended and sold separately) to the solder points (see wiring diagram in Manuals/Resources section on the right) and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Kit includes two 9.8" 12 RGB LED strips, one 4-pin power cable, and 8 additional wires for daisy chaining strips.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 240 mA • Overall dimensions: 0.55" W x 9.84" L x 0.14" H (14 x 250 x 3.5 mm) • Segment dimensions (four segments per strip): 2.5" L (63.3 mm).
RGB LED Specifications: • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
  • BrandParts Express
  • ModelDC-LE12124
  • Part Number073-068
  • UPC844632093685
  • Product CategoryAccent & Party Lighting
  • Weight0.1 lbs.
View similar products to the RGB 12 LED 9.8" Strip Stick 12 VDC 2 Pcs.
in the Accent & Party Lighting product category.
Customer projects that include: RGB 12 LED 9.8" Strip Stick 12 VDC 2 Pcs.
