RESTOCKED Yung SD200 200W Class D Subwoofer Amp Module No Boost
88-301-504_ALT_0
|Model: SD200|Part # 88-301-504
High efficiency and the ability to produce full output continuously are important features of the Yung SD200 200W Class D subwoofer amplifier module, in addition to its small size, high fidelity, and economical price.
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 45 Day No Hassle Returns Policy. Order risk free and take up to 45 days to check it out. If any Open Box item does not meet your standards simply return it within 45 days for a full refund.
View It New
  • Class D amplifier circuit with switching power supply provides excellent efficiency
  • Capable of sustained, continuous output without thermal shutdown
  • Built-in limiter circuit protection prevents peak overloads
  • Low-level and LFE inputs for flexible interconnection
  • Manual and automatic on/off mode options
  • Fully adjustable phase, gain, and crossover points ensure system optimization
  • Switchable 115/230V input voltage
Frequently Bought Together
Yung International's SD Series Class D subwoofer power amplifiers are equipped with the unique ability to operate continuously at full rated output—a performance attribute not shared by most home audio amp designs. The benefits of this remarkable reserve capacity include solid, punchy dynamic range and fewer "nuisance" shutdowns when operated at sustained high levels.
The amplifiers are also extremely compact, lightweight, and cool-running, allowing users to enjoy the advantages of compact system form factors and flexibility of placement. An internal peak limiting circuit prevents amplifier overload, and protection against internal and external faults is also provided. Input power requirements are user configurable to either 115 VAC or 230 VAC line voltage.
Room optimization and system integration are accomplished easily, thanks to the SD Series amps' inclusion of fully variable level, crossover frequency, and phase controls. Signal input is connected via dual RCA-type jacks, including the means to accept the output of an A/V receiver's LFE output, and dual RCA jacks are also provided to facilitate line level loop-through. When in standby mode, the amp's full active operation is engaged by signal presence of less than 1/2 watt.
Specifications: • Measured power output: 200 watts RMS into 4 ohms @ < 1.0% THD • Signal to noise ratio (at rated power): >90 dB • Input sensitivity (@ low level): 210 mV/50 Hz • Low pass adjustment: 40 Hz to 200 Hz • Phase adjustment: Continuously variable from 0º (normal) to 180º (reverse) • Power requirements: Switchable, 115/230 VAC, 50/60 Hz • Dimensions: 8" W x 7" H x 2-1/4" D; Cutout dimensions: 7-1/4" W x 6-1/4" H.
  • ModelSD200
  • Part Number88-301-504
  • Product CategoryRefurbished, Restocked & Open Box Products
  • Weight3.05 lbs.
View similar products to the RESTOCKED Yung SD200 200W Class D Subwoofer Amp Module No Boost
in the Refurbished, Restocked & Open Box Products product category.
