350-080_ALT_0
350-080_ALT_1
Rescue Tape 1" x 12 ft. Green
Brand:|Part # 350-080
Rescue Tape is a self-fusing silicone repair product with infinite uses. First used by the U.S. Military and now seen at consumer and industrial trade shows across America, this is the most versatile and easy-to-use emergency repair product available.
Part # 350-080
  • Self-fusing—creates a permanent air-tight, water-tight seal in seconds
  • Never gets gummy or sticky like electrical or duct tape — no messy cleanup
  • Resists fuels, oils, acids, solvents, salt water, road salt, and UV rays
  • Extremely versatile with an unbelievably long shelf life
  • Incredible 700 PSI tensile strength
  • Insulates 8,000V per layer
  • Withstands temperatures of 500° F
Rescue Tape is a self-fusing silicone repair product with infinite uses. First used by the U.S. Military and now seen at consumer and industrial trade shows across America, this is the most versatile and easy-to-use emergency repair product available. You can repair leaks on plumbing and hoses in a flash, use to insulate electrical wiring or as shrink wrap, wrap tool handles, and much, much more.
Dimensions: 1" x 12 ft. roll.
Rescue Tape has infinite uses!
Here are just a few suggestions:
  • Keep it on board vehicles & equipment for emergency hose repair!
  • Seal leaky hoses, pipes, tubing, lines, & fittings
  • Neaten up lines and extension cords in stowage
  • Wrap tools and handles for a GREAT non-slip grip
  • Wrap wiring harnesses and custom split-looming
  • Waterproof electrical connections and terminals
  • Use it as an emergency fan belt!
  • Make emergency O-Rings
  • Wrap hydraulic fittings and other exposed metal connections to help prevent corrosion
  • Works even over wet, dirty, or oily surfaces!
  • Use it as a tourniquet or emergency wrap over bleeding injuries
  • Wrap it around ANYTHING that you want secure, and it will never leave any sticky residue
Rescue Tape Directions
1.) Wrap Rescue Tape around project by stretching and overlapping onto itself. Stretch at least double to ensure a good bond; for high pressure leaks stretch to maximum amount. The tighter Rescue Tape is wrapped, the quicker and stronger the bond.
2.) Continue wrapping Rescue Tape around project by overlapping 50% onto itself so that ½ the width is covered with the next wrap. The first and last wrap should completely overlap onto the previous wrap for a complete bond. Additional layers may be necessary, and the same process should be used over the previous layers. Rescue Tape works on either side.
3.) Repositioning Rescue Tape is only appropriate in the first few seconds after wrapping. Attempting to reposition Rescue Tape after 1 minute or longer is not recommended. Rescue Tape is not reusable; however, additional Rescue Tape can be applied over project at any time in the future.
http://www.rescuetape.com/images/directions-illustration.png
Additional Suggestions:
For high pressure leaks, additional wrapping may be required. Most hose repairs can be repaired with 3-5 layers in thickness, and wrapping 3 to 5 inches in each direction away from the leak; however, additional strength can be added simply by wrapping more Rescue Tape.
Rescue Tape has essentially a "maximum" stretch. It is important to stretch Rescue Tape to its maximum to avoid having the leak create a bubble.
Rescue Tape - Radiator Hose
For electrical wiring, it is not necessary to stretch tightly. In fact, it will be more resilient to abrasion when it is not stretched as tightly.
This product is provided without warranty, either expressed or implied, of fitness for a specific purpose. Because conditions and methods of use are beyond the manufacturer’s control, neither manufacturer nor seller will assume any responsibility for the use or misuse of this product. This includes, but is not limited to, any consequential damages.
Rescue Tape Suggested Uses
• Emergency Radiator Hose Repair
• Water Hose & Pipe repair
• Boat Rigging
• Coating ends of Rope
• Home & Garden
• Corrosion Protection
• Electrical Insulation
• Weatherproofing Electrical Connections
• Wiring Harnesses
• Wire Bundles
• Sealing Electrical Connections
• Plumbing Repair
• Emergency O-Rings & Seals
• Sport & Tool Handles
• And much, much more!
http://www.rescuetape.com/images/sug-uses-collection.png
http://www.rescuetape.com/images/uses-imagination.png
  • BrandRescue Tape
  • Part Number350-080
  • UPC859184001071
  • Product CategorySelf-fusing Tape
  • Weight0.194 lbs.
View similar products to the Rescue Tape 1" x 12 ft. Green
in the Self-fusing Tape product category.
Part # 350-080
