Replacement Speaker Driver for Bose 901 4-1/2" 1 Ohm
Brand:|Part # 290-922
This driver's parameters were carefully optimized to match the performance of the classic Bose® 901® loudspeaker systems. Individually or in multiples, replacing your legendary but aging speakers has never been easier—or achieved better results.
List Price$39.99
You Save51%
$19.75
Buy 18+$18.50
Part # 290-922
  • Drop-in replacement for Bose 901 drivers
  • Each individual driver is hand checked and tested
  • Fits Series III, IV, V and VI models, and more
  • Optimized cone/coil/suspension for linearity and reliability
  • 1 ohm nominal impedance
  • Premium-quality motor structure maximizes performance
This driver's parameters were carefully optimized to match the performance of the classic Bose® 901® loudspeaker systems. Individually or in multiples, replacing your legendary but aging speakers has never been easier—or achieved better results. The top plate and T-yoke are Japanese-made cold forged low carbon steel. The flat back plate provides a uniform surface area to which the magnet is bonded, and the outside of the back plate is chamfered to maximize flux density in the gap. Critical attention has been paid to the pole piece and voice coil tolerances, thereby assuring high yield and immunity to mechanical issues. High-grade Y-35 strontium ferrite magnet material is utilized in the motor structure to ensure consistent motor force. The cone is made of long fiber New Zealand blue color pulp paper, an ideal material for cone applications and the foam surround of this driver make it almost identical to the original manufacturers appearance, design and performance. It's rigid and just "lossy" enough to produce full, accurate sound. A 2-layer low oxygen copper voice coil is wound on a high temperature resistant polyimide former. Every driver is hand checked and tested, based on a ±2 dB window.
NOTE: This driver has an impedance of 1 ohm, and should be used only to replace the 4-1/2" driver in the Bose 901 (Series III or later) and Bose 802™ loudspeakers. Compatibility with other Bose loudspeaker models or automotive audio systems has not been verified. This product is not manufactured or distributed by Bose Corporation™, the owner of the registered trademarks BOSE®, BOSE 802™ and BOSE 901®.
  • Nominal Diameter4-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance1 ohms
  • Frequency Response83 to 15,000 Hz
  • Sensitivity91.5 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)83.44 Hz
  • DC Resistance (Re)0.76 ohms
  • Voice Coil Inductance (Le)0.11 mH
  • Mechanical Q (Qms)2.4
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)0.24 ft.³
  • Mechanical Compliance of Suspension (Cms)1.08 mm/N
  • Diaphragm Mass Inc. Airload (Mms)3.38g
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Basket / Frame MaterialPolymer
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.2"
  • Baffle Cutout Diameter4.02"
  • Depth2.17"
  • # Mounting Holes3
  • Sealed Volume0.06 ft.³
  • Sealed F3182 Hz
  • Vented Volume0.14 ft.³
  • Vented F3104 Hz
  • BrandParts Express
  • Part Number290-922
  • UPC844632085055
    (25 Reviews)
  • Weight1.8 lbs.
View similar products to the Replacement Speaker Driver for Bose 901 4-1/2" 1 Ohm
