320-518_ALT_0
320-518_ALT_1
320-518_ALT_2
320-518_ALT_3
Red LED Temperature Display with Remote Control
Brand:| Model: ME-PC11121
This temperature display is not only remote controllable, for switching display, it can also act as a thermostat with six different modes of operation.
  • Thermometer and thermostat all in one
  • Waterproof temperature probe and IR remote control included
  • Six different modes of operation
  • Outputs for relay control
320-518
Weight: 0.4125 lbs.
IN STOCK
List Price$24.99
You Save24%
$18.90
Buy 4-up$17.96
Part # 320-518
This red three digit, 7-segment LED temperature display not only reports temperatures measured by the included waterproof probe, it doubles as an advanced thermostat featuring outputs for relay control with six different modes of operation and a wide range of timing trigger choices. Settings can be remotely changed via the included 7-button IR remote control. Typical applications of this unit include PC system cooling control, maintaining aquarium water temperature thresholds, and timing control of devices based upon temperature. Includes temperature probe on a 38" long cable.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: -24°C (-11°F) to 125°C (257°F) • Display resolution: 0.1° (@ -9.9°C/°F to 99.9°C/F), 1° (@ 100°F and above) • Accuracy: ± 0.5°C (-10°C to 85°C) • Modes of operation: Single threshold heat, single threshold cooling, hysteresis heat (maintain range), hysteresis cooling (maintain range), timed open circuit, timed closed circuit • Dimensions: 3.11" (79 mm) W x 1.7" (43 mm) H x 1.43" (36.3 mm) D.
  • BrandParts Express
  • ModelME-PC11121
  • Part Number320-518
  • UPC844632093241
  • Product CategoryPanel Meters
    (3 Reviews)
  • Weight0.4125 lbs.
View similar products to the Red LED Temperature Display with Remote Control
in the Panel Meters product category.
Red LED Temperature Display with Remote Control is rated 2.6667 out of 5 by 3.
Rated 3 out of 5 by from Reasonable for the moneyJust got it delivered a day ago. Initially disappointed, as it seemed unreliable. Today, I replaced the 9V battery with a 12V wall-wart, and it made a world of difference! It actually responds to the remote control now. So even though the specs say it will operate on 8.5V, give it some headroom, and it'll be much happier.No printed manual in the box, so be sure to download it from PE or the manufacturer's site, and be prepared to read it multiple times, do some head-scratching, and interpret it in the light of the fact that it wasn't written by a native speaker of English. The information I wanted was there, just not expressed in the way I'm accustomed.
Date published: 2015-03-09
Rated 1 out of 5 by from Doesn't Work. No Manual. Junk.I wanted a low cost temperature monitor/controller and what I got was essentially junk. P-E should not even offer this thing. First, it came with no documentation, so I had to comb the P-E website looking for it. Once I found it, it was a total let down. The Chines/English translation was plain awful. I was totally unsuccessful in getting this thing to work, other than to display the temperature in degrees, C. I returned it and got my payment back, LESS the shipping, which, in my humble opinion is not right. Everything I have purchased from PE over the past few weeks and as a new customer has been pretty good but this thing was a total let down.
Date published: 2015-01-27
Rated 4 out of 5 by from Great for DIY projects!I bought one over a year ago and liked it so much I bought another. I like the multiple modes and settings. I am using mine to monitor and control fans on a solar heating project. The only problem I have is with the remotes. Both units are temperamental on the remote working... I have found when I am having problems disconnect for the power source and reconnect. Then things usually work fine.
Date published: 2014-12-06
  • 2015-07-04T06:33CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_320-518, PRD, sort_mostRecent
Can I get this in blue with black trim????
Asked by: theconcreteguy
Unfortunately this is only available in the ivory color with the red display. We do have other temperature controllers available in blue, but they do not have a remote and have gray trim.
Date published: 2014-04-21
Are there longer probes available?
Are there longer probes for purchase with this model. Or is there a comparable model with longer probes? I'm looking for anything up to 10 ft.
Asked by: abbbbbb
We do offer replacement probes that are 119" long (9.91 feet).
Date published: 2014-07-28
Can this be used with a SPDT relay to control 80mm case fans to turn on and turn off within a certain tempature range?
Asked by: jlh2003
Yes, it has relay outputs; the connections and specifications are in the users manual available on the right side of the page.
Answered by: Pop Biggs
Date published: 2014-08-02
Need More Information
Is it possible to get the manual for this product? There is a link to a manual but that is for some other device without relay control. I have some uses possibly for this but need to know how control points are set etc.
Asked by: Papa Tom
Tom,No response from tech support for my question on the relay contact specs, so I contacted the manufacture and they sent me this URL for the CORRECT manual: http://www.sure-electronics.net/download/index.php?name=ME-PC11121%20&type=0 click on the download arrow on the right side of the screen.....nice to have the correct manual!BillH
Answered by: BillH
Date published: 2013-01-05
What type of relay should used with this unit?
Asked by: DaveEmmert
The type of relay you'd use would be based not on this device, but on the device you'd be controlling with it. The relay outputs on this display would simply trigger a relay; what kind of relay and what it activates would be entirely up to the requirements of your application.
Answered by: RussR
  • 2015-07-04T08:24CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_320-518, PRD, sort_recentQuestionsFirst
Customer projects that include: Red LED Temperature Display with Remote Control
