320-520_ALT_0
320-520_ALT_1
320-520_ALT_2
Red LED Temperature Display Dual External Sensors
Brand:| Model: ME-TM41123
Quickly measure two remote environments with this temperature display.
  • Measure two environments at once in °C or °F with included probes
  • Auto-sensing brightness and auto temperature conversion
  • Perfect for the precise monitoring rack closets or fish tanks
  • Wide-range working voltage
320-520
Weight: 0.3 lbs.
OUT OF STOCK
Due In: 3/16/2015
List Price$14.99
You Save27%
$10.90
Buy 4-up$10.36
Part # 320-520
Temperature displays offer the ability of measuring two different environments at the same time in Celsius (°C) or Fahrenheit (°F), making it perfect for monitoring the temperature of your equipment closet, computer case, amplifier, fish tank or for comparing two devices under test.
Three 7-segment red LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings and offers the ability to change the display from Celsius to Fahrenheit with a wave of a hand. The small display housing footprint opens up application possibilities and since it can run on 12 VDC (8.5 to 26 VDC working voltage), this display is right at home in your car or truck.
Included with this display are two waterproof NTC thermal probes on 38" long cables that offer durability and precision incorporating the use of UL and CE-certified cables for low voltage drop. 8" power cable included.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: -24°C (-11°F) to 125°C (257°F) • Display resolution: 0.1° (@ -9.9°C/°F to 99.9°C/F), 1° (@ 100°F and above) • Accuracy: ± 1.0°C • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
  • BrandParts Express
  • ModelME-TM41123
  • Part Number320-520
  • UPC844632093258
  • Product CategoryPanel Meters
    (2 Reviews)
  • Weight0.3 lbs.
View similar products to the Red LED Temperature Display Dual External Sensors
in the Panel Meters product category.
Red LED Temperature Display Dual External Sensors is rated 4.0 out of 5 by 2.
Rated 3 out of 5 by from Disappointed so farMaybe I'm not getting it, but that could be because there were no instructions. Seems accurate - is one good plus. But, even though it has .1 F display resolution, it never changes by just .1 or .2 or even .3 degrees. Also, only one temp probe displays at a time and I can't figure out how to change (one is used for internal temp and the other for external temp)! Additionally, the display changes from Celsius to Fahrenheit on its own! From the product description, it says you can wave your hand to change the display. I can't get that feature to work. So, unless I find some manual or instructions somewhere online, or find out this is a defected unit, I'll have to rate this just average at best. I'll update if possible later.
Date published: 2013-03-29
Rated 5 out of 5 by from Sweet....I use two of these in a semi truck. One probe for outside air temp one for inside. One unit located on the dash and one in the bunk area. They are a fraction of the cost compared to units that are made for trucks. I have them wired to remain on all the time... with no issues.
Date published: 2012-01-16
  • 2015-03-03T06:14CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_320-520, PRD, sort_mostRecent
1.) Are the temperature probes thermistors (value? 40Kohms?) or thermocouples?  2.) How do you switch from one probe to the other?  3.) Can the display brightness be dimmed manually?
Asked by: Steve_M
I just received one and it does not appear to work at all with 12 V applied from a battery and with the sensor plugged in to either of the input jacks.  Is there some trick to this?
Asked by: TomNewcastle
Date published: 2014-10-21
  • 2015-03-03T08:03CST
  • loc_en_US, sid_320-520, PRD, sort_recentQuestionsFirst
Customer projects that include: Red LED Temperature Display Dual External Sensors
