073-082_ALT_0
073-082_ALT_1
Red Laser Light Pointer Module 650nm 5mW
Brand:|Model: DC-LP11112|Part # 073-082
Never make a mistake again when using tools or levels by adding this small, powerful red laser module. The small metal body is both durable and easy to hide. Simply add a switch, power source, and mount the module—you'll be saving time and money in no time flat!
Part # 073-082
  • Small laser module adds precision to almost anything!
  • Low 3 to 4.5 VDC power requirement
  • Range of up to 600 meters (1,968 feet)
  • 5 mW of output power
Add perfect precision to any tool or level—virtually anything where accuracy counts—with this do-it-yourself high-power red laser module. Designed to work off an incredibly low power source of 3 to 4.5 VDC (such as a single CR2032 coin cell battery), the laser module provides up to 5 mW of output with a range of up to 600 meters—almost 2,000 feet!
A removable threaded bezel allows for flush mounting of the laser's housing; an adjustable internal lens offers beam divergence or convergence adjustability. The small metal body is both durable and easy to hide. Simply add a switch, power source, and mount the module (to virtually anything with a standard 1/2" cable clamp)—you'll be saving time and money in no time flat!
Caution: Do not stare directly into the aperture of the laser pointer. Do not point at other people's eyes. Keep out of reach of children.
• Color: Red
• Wavelength: 630~680 nm
• Output power: ≤ 5 mW
• Range: Up to 600 meters
• Dimensions (Diameter x Length): 0.47" x 1.3", 12 x 33 mm
• Power lead length: 4.72", 120 mm
  • BrandParts Express
  • ModelDC-LP11112
  • Part Number073-082
  • UPC844632098437
  • Product CategoryMiscellaneous Tools
    (4 Reviews)
  • Weight0.0875 lbs.
View similar products to the Red Laser Light Pointer Module 650nm 5mW
in the Miscellaneous Tools product category.
