Red Flashing 5mm LED
Brand:|Part # 070-026
This flashing LED features a built-in flashing circuit that operates on 3-5 VDC. Red in color with color diffused lens in the industry standard T-1 3/4 (5 mm) case style.
$0.60
Buy 10-99 $0.55
Buy 100+$0.48
Part # 070-026
This flashing LED features a built-in flashing circuit that operates on 3-5 VDC. Red in color with color diffused lens in the industry standard T-1 3/4 (5 mm) case style. 60° viewing angle. Typical forward voltage range: 3-5 VDC, 20-30 mA.
  • Size5mm (T-1 3/4)
  • Emitting ColorRed
  • Lens Type / ColorRed Diffused
  • Application TypeFlashing
  • BrandParts Express
  • Part Number070-026
  • UPC844632042171
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.0013 lbs.
Red Flashing 5mm LED is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from "Flashing" LEDReally my fault being a novice at electronics, but this is hardly a flashing LED. I would call it a flickering LED as the rate of "flash" is extremely rapid. I will need to add a timing circuit to get it to flash and this is what I was trying to avoid.
Date published: 2009-01-02
  • 2016-02-12T06:33CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_070-026, PRD, sort_mostRecent
Is there a 1.7-2.2 Vdc flasing led
Asked by: jrmasi14
Unfortunately this is the only voltage range we offer for our flashing LEDs.
Date published: 2013-01-14
What is the rate of flash?
Asked by: Anonymous
A flashing led is an led that has an integral circuit that does not control the rate. This circuit controls the phosphorus lamp coating to allow dead off/on illumination when powered by the control voltage switching.Because of this, without a rate control the led will flash according to the input voltage frequency. If you use USA line current then your frequency is 60Hz. The led is basically a diode (light emmiting diode) (LED) so it will see only the + cycle and a rate of 30 flashes per second (fps) are likely. This rate is more of a flicker than a flash.Check out simple IC 555 clock circuits on line. It is low cost and very easy. You can substitute a fixed resistor with a similar valued variable resistor to get a variable flash rate.
Answered by: Nitnub
Date published: 2013-09-18
  • 2016-02-12T07:14CST
  • loc_en_US, sid_070-026, PRD, sort_recentQuestionsFirst
Part # 070-026
