RE Audio ZTX800.4-v2 800 Watt 4 Channel Amplifier
Brand:|Model: ZTX800.4-v2|Part # 268-8190
RE Audio's ZTX Series full-range amplifier's revolutionary new cosmetic design incorporates a wooden top plate with a black lacquer finish and a backlit RE logo. These sleek-looking amplifiers go "beyond the limit" by including sound and power classes that match perfectly with all RE Audio speaker and subwoofer systems.
Part # 268-8190
  • Class AB full range amplifier with RCA and speaker-level input
  • 40 to 250 Hz, 12 dB/octave high-pass crossovers
  • 40 to 250 Hz, 24 dB/octave low-pass crossovers
  • 0 to 18 dB bass boost (centered at 45 Hz)
  • 2-ohm stable, 4-ohm bridgeable amplifier capable of 440 watts RMS
The ZTX800.4-v2 four-channel amplifier uses a Class AB amplifier topology to create 440 watts of RMS power into four 2Ω loads (@ 14.4 VDC). Each set of channels can be wired for bridged-mono operation, yielding two channels of 210 watts of RMS power into 4Ω loads.
Each channel set features selectable and variable high-pass filters that can be set from 40 Hz up to 250 Hz (12 dB/octave), an adjustable 40 to 250 Hz (24 dB/octave) low-pass filter, or can be set to run full range. Variable 0 to 18 dB bass boost (centered @ 45 Hz) can also be applied to all channels.
Features and Specifications:
• Power output:
         85 watts x 4 (@ 14.4V, 4Ω)
         110 watts x 4 (@ 14.4V, 2Ω)
         210 watts x 2 (@ 14.4V, 2Ω)
• Total Harmonic Distortion: <0.02%
• Frequency response: 10 to 30,000 Hz (-3 dB))
• Input type: Line-level and speaker-level
• Input sensitivity: 200 mV to 2V
• Thermal, DC offset, overload, and speaker short protection
• Signal-to-noise ratio: 90 dB
• Crossover:
         LP (variable): 40 to 250 Hz, 24 dB/octave
         HP (variable): 40 to 250 Hz, 12 dB/octave
• Bass boost: 0-18dB (centered @ 45 Hz)
• Fuse rating: 35 amps x 2
• Dimensions (L x W x H): 14.06" x 9.45" x 2.44"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)85 Watts
  • Special FeaturesBridgeable,Preamp Outputs,2 ohm Stable
  • Output Channels4
  • BrandRE Audio
  • ModelZTX800.4-v2
  • Part Number268-8190
  • UPC611892991828
  • Product CategoryCar Amplifiers
  • Weight8.1500 lbs.
View similar products to the RE Audio ZTX800.4-v2 800 Watt 4 Channel Amplifier
in the Car Amplifiers product category.
