RE Audio ZTX5000.1-v2 5000 Watt Digital Amplifier
Brand:|Model: ZTX5000.1-v2|Part # 268-8192
RE Audio's ZTX Series digital, full-range amplifier's revolutionary new cosmetic design incorporates a wooden top plate with a black lacquer finish and a backlit RE logo. These sleek-looking amplifiers go "beyond the limit" by including sound and power classes that match perfectly with all RE Audio speaker and subwoofer systems.
Part # 268-8192
  • Digital subwoofer amplifier with RCA connection
  • 40 to 180 Hz, 24 dB/octave low-pass crossover
  • 17 to 50 Hz, 24 dB/octave subsonic crossover
  • 0 to 18 dB bass boost (centered at 45 Hz)
  • Wired remote control
Frequently Bought Together
The ZTX5000.1-v2 monoblock amplifier uses a digital Class D amplifier topology to create up to 2500 watts of RMS power into a 1Ω load (@ 14.4 VDC). This stunningly sophisticated amplifier would make a great addition to any large car audio system, especially competition car audio SPL systems!
A variable 40 to 180 Hz (24 dB/octave) low-pass crossover is built into the RE Audio ZTX5000.1-v2, and a variable 0 to 12 dB bass boost (centered @ 45 Hz) is available to dial-in even more bass. To protect ported subwoofers, an adjustable 17 to 50 Hz (24 dB/octave) subsonic filter can also be applied.
Note: • 250 amps x 1 external fuse must be used (sold separately)
Features and Specifications:
• Power output:
         1000 watts x 1 (@ 14.4V, 4Ω)
         1700 watts x 1 (@ 14.4V, 2Ω)
         2500 watts x 1 (@14.4V, 1Ω)
• Total Harmonic Distortion: <0.05%
• Frequency response: 17 to 180 Hz (-3 dB)
• Input type: Line-level (RCA only)
• Input sensitivity: 600 mV to 6V
• Thermal, DC offset, overload, and speaker short protection
• Signal-to-noise ratio: 90 dB
• Crossover:
         LP (variable): 40 to 180 Hz, 24 dB/octave
         Subsonic (variable): 17 to 50 Hz, 24 dB/octave
• Bass boost: 0-18dB (centered @ 45 Hz)
• Dimensions (L x W x H): 21.75" x 9.45" x 2.44"
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)1,000 Watts
  • Special FeaturesPreamp Outputs,1 ohm Stable,2 ohm Stable
  • Output Channels1
  • BrandRE Audio
  • ModelZTX5000.1-v2
  • Part Number268-8192
  • UPC611892992191
  • Product CategoryCar Amplifiers
  • Weight14.6500 lbs.
View similar products to the RE Audio ZTX5000.1-v2 5000 Watt Digital Amplifier
in the Car Amplifiers product category.
