RCF ND3020-T3 2" Neodymium Horn Driver
Brand:|Model: ND3020-T3|Part # 294-826
The RCF ND3020-T3 is a high frequency performance 3" voice coil compression driver featuring several state of the art technologies.
Part # 294-826
  • Direct drive 3" voice coil assembly
  • Compact neodymium magnet assembly
  • 0.05 mm thick pure titanium diaphragm
  • Vented, damped, low distortion, variable-profile suspension system
  • 3-slot optimized-geometry phase plug
  • Copper inductance ring for extended response
  • Aluminum rear cover featuring an advanced vented fin heat dissipation design
The RCF ND3020-T3 is a high frequency performance 3" voice coil compression driver featuring several state of the art technologies. The diaphragm and suspension are precision formed from titanium, and the suspension is based on an innovative design using progressive parabolic semicircles. The ND3020-T3's compact size and 2" exit throat make it especially suited for 2-way and multiple-way long throw systems as well as medium and large format line arrays.
Specifications: • Power handling: 110 watts RMS/220 watts program above recommended crossover of 1.2 kHz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-20,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 5.5" diameter x 3.9" depth • Net weight: 7.5 lbs. • Replacement diaphragm available.
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)110 Watts
  • BrandRCF USA
  • ModelND3020-T3
  • Part Number294-826
  • UPC844632089947
  • Product CategoryHorn Drivers
  • Weight7.55 lbs.
View similar products to the RCF ND3020-T3 2" Neodymium Horn Driver
in the Horn Drivers product category.
