RCF N850 2" Horn Driver
Brand:|Model: N850|Part # 294-816
For long throw and large format line arrays, RCF has produced the N850 — a high quality 3" diaphragm/2" exit compression driver.
List Price$493.00
You Save29%
$350.00
Part # 294-816
  • For high-power pro applications
  • 0.05 mm thick titanium diaphragm
  • Vented Mylar suspension system
  • Edgewound aluminum ribbon wire
  • Copper inductance ring for extended response
  • 3-slot optimized-geometry phase plug
  • Aluminum rear cover and front adapter
For long throw and large format line arrays, RCF has produced the N850 — a high quality 3" diaphragm/2" exit compression driver. Its diaphragm is precision formed from 0.05 mm thick pure titanium with a vented Mylar suspension. The front aluminum adapter guarantees a very smooth transition from the phase plug to the 2" output. The N850 offers very good linearity in combination with the RCF HF6040 horn. Standard 4-bolt mounting. Suitable replacement HF driver for a variety of EAW loudspeaker systems.
Specifications: • Power handling: 90 watts RMS/180 watts program above recommended crossover of 1.2 kHz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-20,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 7.1" diameter x 7.3" depth • Net weight: 10.3 lbs. • Replacement diaphragm available.
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)90 Watts
  • BrandRCF USA
  • ModelN850
  • Part Number294-816
  • UPC844632089886
  • Product CategoryHorn Drivers
  • Weight14.3 lbs.
View similar products to the RCF N850 2" Horn Driver
in the Horn Drivers product category.
Part # 294-816
