RCF MR8N301 8" Neodymium Midrange Speaker
Brand:|Model: M48N301|Part # 294-832
RCF's MR8N301 is a high efficiency, high power midrange specially designed to provide superior sound pressure levels in a very compact size.
List Price$580.00
You Save29%
$411.00
Part # 294-832
  • 3" inside/outside aluminum voice coil
  • 400 watt continuous program power handling
  • 300 Hz – 3 kHz frequency range
  • High BL neodymium magnet system
  • Unique aluminum sealed basket features a vented fin heat dissipation design
  • Calibrated back volume for perfect time domain transient reproduction
RCF's MR8N301 is a high efficiency, high power midrange specially designed to provide superior sound pressure levels in a very compact size. The total weight is reduced to less than half of a comparable ceramic midrange thanks to an incredibly powerful neodymium magnet assembly. The unique sealed basket doesn't require a back-sealing chamber, simplifying the cabinet design and improving heat dissipation. Every detail of the MR8N301 has been optimized to offer the best response and perfect control of the midrange frequencies, and it is especially designed for horn-loaded and line array configurations. The combination of the 3" voice coil, neodymium motor, and heat sink basket design makes this driver the ideal solution for the most demanding applications. Suitable replacement midrange driver for many L'Acoustics line array loudspeaker systems.
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response300 to 3,000 Hz
  • Sensitivity102 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)310 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)1.16 mH
  • Mechanical Q (Qms)3.45
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.06 ft.³
  • BL Product (BL)17.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.1g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)210 cm²
  • Cone MaterialPaper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter9.4"
  • Baffle Cutout Diameter8"
  • Depth4"
  • # Mounting Holes4
  • Sealed Volume0.01 ft.³
  • Sealed F3578 Hz
  • Vented Volume0.04 ft.³
  • Vented F3332 Hz
  • BrandRCF USA
  • ModelM48N301
  • Part Number294-832
  • UPC844632089978
    (1 Reviews)
  • Weight8.3 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the RCF MR8N301 8" Neodymium Midrange Speaker
