RCF MB8G200 8" Midbass Speaker
Brand:|Model: MB8G200|Part # 294-830
The MB8G200 is a professional midbass woofer featuring very high output and dynamics. Its 2" copper voice coil on a fiberglass former enables excellent transient peak response and good mid-high frequency extension.
ORDER TODAY
Ships in 3-10 business days
List Price$256.00
You Save29%
$182.00
Part # 294-830
  • High efficiency and detailed sound quality
  • M-roll damped surround and exponential cone geometry
  • 2" copper voice coil on fiberglass former
  • Specially designed for compact, dynamic, high efficiency systems
The MB8G200 is a professional midbass woofer featuring very high output and dynamics. Its 2" copper voice coil on a fiberglass former enables excellent transient peak response and good mid-high frequency extension. A specially designed M-roll surround guarantees low midrange distortion and perfect damping of spurious resonances, and an inverted dust cap minimizes cone break-up. The MB8G200 is the ideal low frequency transducer for very compact, high efficiency, bass reflex systems where maximum dynamic range is required.
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity94 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)76 Hz
  • DC Resistance (Re)4.8 ohms
  • Voice Coil Inductance (Le)1.4 mH
  • Mechanical Q (Qms)3.7
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)0.39 ft.³
  • BL Product (BL)12.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)25g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)210 cm²
  • Cone MaterialTreated Paper
  • Voice Coil FormerFiberglass
  • Overall Outside Diameter9.4"
  • Baffle Cutout Diameter7.24"
  • Depth3.7"
  • # Mounting Holes4
  • Sealed Volume0.06 ft.³
  • Sealed F3197 Hz
  • Vented Volume0.16 ft.³
  • Vented F3120 Hz
  • BrandRCF USA
  • ModelMB8G200
  • Part Number294-830
  • UPC844632089961
  • Weight8.85 lbs.
View similar products to the RCF MB8G200 8" Midbass Speaker
Part # 294-830
