RCF MB15N401 15" Neodymium Midbass Speaker
Brand:|Model: MB15N401|Part # 294-870
RCF's MB15N401 is a neodymium midbass with linear frequency response and very high efficiency.
ORDER TODAY
Ships in 7-10 Business Days
List Price$645.00
You Save29%
$457.00
Part # 294-870
  • Very efficient low-distortion midbass driver
  • Strong, lightweight neodymium magnetic structure
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,700 watt continuous program power handling
  • Aluminum demodulation ring
  • Single spider design with silicon based damping control
  • Triple roll surround and exponential cone geometry
RCF's MB15N401 is a neodymium midbass with linear frequency response and very high efficiency. To achieve this performance, the magnetic structure uses a demodulation ring and a fiber-loaded exponential cone assembly, along with a high excursion triple-roll, constant geometry surround. The fiberglass former, inside/outside, copper voice coil provides excellent thermal and mechanical durability, and the aluminum demodulation ring guarantees fast time response and low distortion. The MB15N401 is ideal for use in applications requiring good power handling, very high efficiency, and perfect linearity. It is the ideal 15" woofer for midbass applications in compact 2-way systems.
  • Nominal Diameter15"
  • Power Handling (RMS)850 Watts
  • Power Handling (max)1700 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity100 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.6 mH
  • Mechanical Q (Qms)7.7
  • Electromagnetic Q (Qes)0.2
  • Total Q (Qts)0.19
  • Compliance Equivalent Volume (Vas)4.8 ft.³
  • BL Product (BL)26.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)100g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)910 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth6.2"
  • Bolt Circle Diameter14.7"
  • # Mounting Holes8
  • Sealed Volume0.29 ft.³
  • Sealed F3172 Hz
  • Vented Volume0.53 ft.³
  • Vented F3115 Hz
  • BrandRCF USA
  • ModelMB15N401
  • Part Number294-870
  • UPC844632090158
  • Weight19 lbs.
View similar products to the RCF MB15N401 15" Neodymium Midbass Speaker
