RCF MB15N351 15" Neodymium Midbass Speaker
Brand:|Model: MB15N351|Part # 294-862
The RCF MB15N351 delivers excellent frequency response linearity with low distortion.
List Price$537.00
You Save29%
$381.00
Part # 294-862
  • Very efficient low-distortion midbass driver
  • Strong, lightweight neodymium magnetic structure
  • 3.5" diameter inside/outside copper voice coil on fiberglass former
  • 1,300 watt continuous program power handling
  • Single spider design with silicon based damping control
  • M-roll surround, light moving mass, and exponential cone geometry
  • Dual forced air ventilation for minimum power compression
The RCF MB15N351 delivers excellent frequency response linearity with low distortion. A very strong neodymium magnetic structure guarantees great dynamics and precision reproduction, while a new and unique 3.5" voice coil design provides high power handling, especially in comparison to a more common 3" voice coil. The unique dual forced air venting system promotes efficient voice coil ventilation to minimize power compression and maximize power handling. The MB15N351 is ideal for use in applications that require very high efficiency and linearity. It is especially recommended for concert-level multi-way systems.
  • Nominal Diameter15"
  • Power Handling (RMS)650 Watts
  • Power Handling (max)1300 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity100 dB 2.83V/1m
  • Voice Coil Diameter3.5"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.65 mH
  • Mechanical Q (Qms)4
  • Electromagnetic Q (Qes)0.24
  • Total Q (Qts)0.22
  • Compliance Equivalent Volume (Vas)6.75 ft.³
  • BL Product (BL)22.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)80g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)1650 cm²
  • Cone MaterialPaper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth6.4"
  • # Mounting Holes8
  • Sealed Volume0.45 ft.³
  • Sealed F3163 Hz
  • Vented Volume0.96 ft.³
  • Vented F3107 Hz
  • BrandRCF USA
  • ModelMB15N351
  • Part Number294-862
  • UPC844632090110
  • Weight14.65 lbs.
View similar products to the RCF MB15N351 15" Neodymium Midbass Speaker
